586,105 active members*
3,324 visitors online*
Thread: Hoss's G0704
Page 12 of 344 210111213142262112
Results 221 to 240 of 6871
  1. #221
    Feb 2010
    3447
    Talking
    Grizzly called me today and confirmed that G0704 parts are going to be available on a confirmed date of December 3rd. He said no more, estimates its a for sure locked in date. (my order and some prices below, to change my random Mt3 taper grizzly over to R8, i got it at there tent sale, i don't believe they offer any MT3 parts FYI). Those are the prices though if anyone is interested, or just wondering how much they charge for stuff. Maybe more G0704's will come in with that shipment if anyone else wants to buy one?
    1 P0704246 SPINDLE R8
    EA 60.00
    1 P0704246-1 DRAWBAR
    EA 7.50
    1 P0704246-2 RETAINER CUP
    EA 3.00
    1 P0704247 SPINDLE RING
    EA 4.50
    1 P0704249 QUILL SLEEVE
    EA 54.00
    1 P0704250 RUBBER RING
    EA 1.25
    1 P0704251 ADJUSTER NUT
    EA 6.00
    2 P0704252 ADJUSTER NUT SCREW
    EA 1.25 2.50
  2. #222
    Apr 2005
    1268
    Hoss;
    An off topic question for you if I may!! I'm tooling up with the tormach type tool holders using your prints since there maybe a possibility of an ATC down the line! My question is, is there a reason for the .1" counter bore on the back of the tool holder body? I have a set of original tormachs and noted the originals have the same recess. But in my R8 holder, I can't figure out why a solid back wouldn't work just as well. Have you considered this?
    I don't have a decent tool for cutting that recess so it's just a PITA.
    What am I missing?
    Thanks for all of the Hoss entertainment I've enjoyed for years!!!
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
  3. #223
    Jun 2004
    822
    I had the same question for Hoss a while back on the TTS holders. I don't recall his answer but I think it is to clear the R8 collet if it sticks out. That is the part that has been hanging me up (and breaking cutters). I think I will just recess the collet more and leave them flat if that will work.
    On yet another unrelated note - has anyone completely trammed their G0704 in yet? I started doing mine this morning and I am sure I am doing it the wrong way but here are some observations:
    I do not have a cylinder square so in order to determine how perpendicular the column was to the table, I mounted a DTI in the spindle and ran it up and down an angle plate mounted to the table.
    1) The column was pretty good in the X plane - under .0005
    2) The column was out .003 to .004 over 4" or so in the Y plane. To fix this, I shimmed a small amount between the column and base (behind the Y dovetails). This brought it to under .0005 over the same distance
    Once I thought the column was perpendicular to the base, I wanted to tram the head so I used the same indicator on the spindle and swept the table. I first just concentrated on the reading at 3 o clock and 9 o clock to get the head into the right position. This is a pain unless I am doing it wrong because you have to first loosen the head's upper bolt (which will allow it to fall out from the column a little), then loosen the swivel bolt in order to move it, then re-tighten it and take your measurement.
    Once the 3:00 and 9:00 read the same, I then looked at 12:00 and 6:00 which vary by a good .005". I really hate to shim the head since it swivels and it would be a pain to have to do that every time. Now I am wondering if either I did the column to base adjustment way wrong or it is now fixed but they initially squared the head in with an unaligned column.
    any thoughts?
  4. #224
    Aug 2005
    48
    Quote Originally Posted by bill south View Post
    Hoss;
    What am I missing?
    Bill
    Just thinking aloud and I may be completely wrong so take this for what it is worth... If you turn the tool holder to a shoulder, wouldn't there still be a slight radius depending on the turning insert used? This would cause repeatability issues as the mating surface is no longer flat. By adding the recess, you remove the edge with the radius meaning the mating surface is now completely flat.
  5. #225
    Jun 2004
    6618
    Tormach sells an R8 collet that is flat on the end.
    The recess isn't always needed on these, but needs to be there for other collets with a proud face. The extra clearance is good to have. To do this correctly, I had to mill my spindle face a bit to get the holders to seat properly. Not much material was removed, but once done, the TTS holders slipped in and out much easier. I had to check the tram, but was still close enough for me.
    Mine is not a 704, but I suspect the same may need doing.
    Lee
  6. #226
    Dec 2009
    1416
    I had the same issue with tram in the Y plane in my PM-25. I had to shim a bit to bring it in to about 0.002" over the width of the table. As I know I will almost never tilt the head I'll just have to live with it. When I go to CNC the Z axis I plan to drill holes for two more bolts to hold the head and that should allow me to pull out the last thousanth or so of nod in the mill's head, hopefully without the shims.
    I did have to shim my column as well to get it back into tram after I tore it down to move to the basement. As for X tram:
    http://www.cnczone.com/forums/769033-post14.html
    Make these, there is really no way to describe how much easier it is to tram now. I made one for each side and now tramming in is a simple matter of loosening just slightly turning opposing set-screws and then retightning. Beats the hell out of pounding with rubber hammers. Also helps hold tram even through the occasional too-heavy cut or bump.
  7. #227
    Jun 2004
    822
    I saw that thread - I think I will make those tonight. How did you check the column? Did you use a cylinder square or another method?
  8. #228
    Dec 2009
    1416
    Couldn't obtain a good cylinder square so I ended up using the blade edge of a 8" china square to set it. I clamped it lightly in the vise and got the Y set with shims and then moved it to the X direction and tapped the column in. It's still not perfect, but I don't trust the square completely either. I don't seem to have much problem with hole locations between small and large bits though and that was all I wanted to avoid.
  9. #229
    Jul 2007
    1602
    Regarding the undercut on the TTS flanges see section 1.2 Principles of Operation: http://www.tormach.com/document_libr...TTS_Manual.pdf
    bob
  10. #230
    Apr 2005
    1268
    Thanks Guys for the TTC information. I was not aware that Tormach had two different R-8 adapters. My model is the flat faced model so it didn't make sense to have a recess. I'm going to order a spare and if the new adapter has a rounded face, I'll end up buying a grooving boring bar and doing the work.
    Thanks again.
    Bill
    billyjack
  11. #231
    Sep 2010
    So, do the G0704's come with inspection reports like some of the other BF20's come with?
    Hoss, do your z gibbs look any better that some that have come with the BF20's?
  12. #232
    Quote Originally Posted by wmacky View Post
    Either I didn't get an inspection report or I missed it, I got one of the first G0704's, maybe they forgot, I don't remember seeing one.
    I yanked it apart immediately so it didn't matter.
    The gib strip is machined on 3 sides and scraped on one side, nice and flat.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  13. #233
    Jun 2008
    614
    Quote Originally Posted by hoss2006 View Post
    Hoss
    i didnt get an inspection report either...
    my gibs look very nice also, the Z gib looks like someone bit it off to length rather than cut it...but it works good...nice and smooth
    http://www.g0704.blogspot.com/
  14. #234
    Sep 2010
    Thanks guys, That's good news. Even if I were to get a bad one, it sounds like a probable good replacement gibb would be possible.
    I'm getting nervous about the whole freight thing. Never had a "freight" shipment before! I'll need to request a short notice day off work, and I hope I can get lift gate delivery. My current vehicle is a Jeep!
  15. #235
    Feb 2010
    3447
    Both of mine came with full inspection reports and someone actually wrote out all the specs of accuracy in each test. I can snap a pic if you want, its kinda nice cause it basically tells me how the heck to verify all these measurements with pictures haha. <----nooob
  16. #236
    Jun 2004
    822
    Would anyone mind making a video of how they adjust the Z gib? No matter how I do it, it just doesn't feel right. And even when it seems tight (or even too tight), tightening the lock will cause the head to deflect.
  17. #237
    Dec 2009
    1416
    Quote Originally Posted by mrcodewiz View Post
    Welcome to my world on the PM25. If I don't lock it then surface finish suffers, if I do then the tool deflects about 0.002" to the side give or take. I have to tram the thing to the locked condition and know that it's out of tram and out of position when unlocked. All tightening it down does for me is change which lever causes the head to shift. I have a new gib strip ordered. I want to see how they compare to each other but I may just make my own down the road to see if I can shape it to fit better. When I turn the top lock I can see the gib actually flex a bit so I think it just doesn't fit well. When I take the head off again I plan to double check for any grit or debris but I'm pretty sure that this is just a bad fitting gib, or more ominously a poorly cut recess for it.
  18. #238
    Jun 2004
    822
    Aren't the gibs scraped in for the specific machine or is the scraping on them purely cosmetic?
  19. #239
    Dec 2009
    1416
    One would hope they were custom but I'm not sure I would expect it to have been done that well if at all for these Chinese machines. We'll see when my replacement gets here in Nov.
  20. #240
    Jun 2003
    232
    At some point in the future I might purchase a G0704 and CNC it. At present I have a Taig Mill with a Deepgroove1 Gecko G540 control box which I would like to use in the conversion. I know that I would have to get a larger power supply for it but I am would like to know the best available stepper combination to use with the G540.
    On this page G0704 Electronics Hoss suggests:
    "Bare Minimum Recommendation - This runs at 50 Volts but only 3.5 Amps
    Should be easier for newbies to setup but is definitely weaker. Don't expect
    to be able to hog as much metal with this setup.**
    (1) Geckodrive G540 4 Axis driver - $249 (with other purchase)
    (2) KL23H2100-35-4B 381 oz-in stepper motor (X and Y axis) $49 / $98
    (1) KL23H2100-30-4BM 495 oz-in stepper motor (Z axis) / $59.95 *
    (1) KL-600-48 48V/12.5A power Supply / $129.95
    Total = $536.90
    * Run with a 1.33:1 pulley ratio (24 and 32 tooth pulleys) for 658 oz/in output."
    But on Keling's page Page Title one of the packages is:
    "G540 3 axis package (one G540 + one KL34H295-43-8B, 906 oz-in +
    Two KL23H2100-35-4B (1/4” Dual shaft with a flat) 381 oz-in + one
    KL-600-48 48V/12.5A 115V /230V
    power supply): $581.95"
    It would seem that the Keling package would not require the 1.33:1 pulley ratio that Hoss suggests. In fact it would allow a Z axis stepper larger than the 570 oz-in stepper Hoss uses now. I realize that this probably not the optimum combination but it would speed up the Z axis.
    Bottom line question, is there a better stepper combination for the G0704 using the Geckodrive G540 4 Axis driver that would perform better than Hoss's Bare Minimum Recommendation?
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
