It has some kind of torque compensation. If the motor is loaded and starts to slow down the system tries to up the power and so sometimes it will rev higher as you enter the cut. I usually only get that when I'm running low rpm in high gear and start cutting. In low gear It will not break a sweat even in steel.
I wonder if it's compensation was going overboard and popped the SCR?
I have been cutting aluminum with near any DOC my endmills can handle from 17-25 IPM. I only have to go slow with the small endmills because of limited RPM.
CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
