586,089 active members*
3,870 visitors online*
Thread: Hoss's G0704
Page 211 of 344 111161201209210211212213221261311
Results 4,201 to 4,220 of 6871
  1. #4201
    Jul 2003
    1754
    couple of thoughts..
    -With your 3phase motor and vfd - all you need is a spindle encoder and you can rigid tap. (without a servo) Linuxcnc does spindle synced motion.
    -you have a rotory axis on your spindle I see. It isn't for the faint of heart but linuxcnc does kinematics. it can do the math to translate from joint/axis motion to 'part' motion. It makes gcode programming much easier. there are some sample configs.. but like I say - you would have to read up.
    https://www.youtube.com/watch?v=0jQy-zc5P6w
    https://www.youtube.com/watch?v=aF7C8d4d0nc
    https://www.youtube.com/watch?v=DjPCEpZybXs
  2. #4202
    Jun 2010
    1414
    I will be watching your VFD install like a hawk. I will be doing the same for my Tormach Build. I don't know anything about them, so what better thread to turn to
  3. #4203
    Quote Originally Posted by Fastest1 View Post
    Uh Oh, I see all of the toys and more on the mill now. Only time will tell.
    More to come.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  4. #4204
    Quote Originally Posted by samco View Post
    Thanks, yes I need to get into linux cnc more and more.
    Hoss
  5. #4205
    Quote Originally Posted by nateman_doo View Post
    Thanks I'll try and show it as well as others already have.
    Hoss
  6. #4206
    Got the 56C motor in, boy it's heavy.
    Went ahead and ordered the Vector VFD from Dealers today and they shipped today.
    When I get the RC motor in from the slow boat I'll show a comparison lineup of all the motors I have.
    Hoss
  7. #4207
    Aug 2009
    65
    Quote Originally Posted by phomann View Post
    Hi Pete,
    I'm converting a TM20LV mill using belts and tucking the X-motor in front of the table. Also the Y motor is tucked back beside the mill base.
    TM20VL Mill CNC Conversion X-Axis (Part 2)
    http://www.cnczone.com/forums/bencht...ghlight=homann
    It may give you some ideas.
    Cheers,
    Peter
    Peter, great thanks for the links, I'm way behind on my thread reading, and Hoss waits for no man! I'll check them out.
    Ricce, thanks for your offer as well.
    My much neglected build thread is here.
    another_g0704_conversion-hosss_plans-linuxcnc_control
    Pete
    Sorry about the highjack Hoss.
  8. #4208
    SDP-SI was out of stock on the L belt I needed for the 3 phase motor and mcmaster didn't carry the length I needed
    so I jumped on google and found this site that had it and much cheaper too.
    Industrial Timing Belts & Pulleys Polytech Design Inc. Clifton NJ 07011
    Hoss
  9. #4209
    Jan 2006
    115
    Nice find Hoss! I have spent many hours looking for the best deal on the HTD 5mm 40tooth pulleys I need. Only found it cheaper one other place (by only a couple $) but they had a minimum order of 3 units and I only need 2. I think I know now where I'm going to get my pulleys next week.
  10. #4210
    Yeah they have a $15 min order, i actually had to add an extra belt for the rc motor to just get there.
    It's all good.
    Hoss
  11. #4211
    Jan 2012
    469
    Quote Originally Posted by punisher454 View Post
    I do this all the time, so I'll help you out by pointing it out to you - is it worth spending hours to save a couple of bucks? :P Whenever I notice myself getting stuck in a loop trying to work out the best way to save 10 bucks, I just try to do an hour of overtime and work and splurge on the "good" stuff haha.
  12. #4212
    Jan 2006
    115
    Quote Originally Posted by TiagoSantos View Post
    Oh I know it. But I have to say that by having done this for years I have really improved my "finding a good deal on the internet" skills a lot.
    But yes I do have to just stop my self sometimes, its almost like gambling.
  13. #4213
    I should have watched more julia child, this batch of cookies did not turn out, should have listened to mom.:nono:
    Better luck next time.
    Hoss
    Attached Thumbnails Attached Thumbnails 101_1988_cropped_782x600.jpg   101_1989_cropped_673x600.jpg
  14. #4214
    Jun 2010
    1414
    Which VFD did you end up getting? Why did you choose it, and am I reading that you are buying a toothed belt for the 3 phase? That belt place is about 30 minutes from me
  15. #4215
    I ordered the one from Dealers I mentioned here.
    http://www.cnczone.com/forums/1214330-post4160.html
    It's a great price on a sensorless vector VFD to go with the same motor mentioned.
    Hoss
  16. #4216
    Sorry for the short reply, duty called.
    Adding on, I'm learning this too.
    I read these pdf's to learn about things like FLA, CT, VT and more.
    http://wmea.net/Technical%20Papers/S...ency_Drive.pdf
    http://www.danfoss.com/NR/rdonlyres/...vfdlesson4.pdf
    http://www.automationdirect.com/stat...sselection.pdf
    http://www.tecowestinghouse.com/Manu...stallation.pdf
    http://www.automationdirect.com/stat...nhorsetprs.pdf
    The Dykman pdf explained things well.
    Hoss
  17. #4217
    If you want to learn more about 3-phase motors, I watched these vids by Lewellyn on youtube, he really makes it easy to understand.
    [ame="http://www.youtube.com/watch?v=6H_MkhwAmz4&list=FLjoRKEpk7uE5Wzf4b-IFTFg&index=3"]Three-Phase Induction Motors - MyToolboxTV Ep. 3 - YouTube[/ame]
    [ame="http://www.youtube.com/watch?v=dZN3IroGkzI&list=FLjoRKEpk7uE5Wzf4b-IFTFg&index=2"]Motor Nameplate Data - MyToolboxTV Ep. 11 - YouTube[/ame]
    This line from the Teco manual notes a few of main specs to verify when matching the motor to the VFD.
    • Check inverter and motor nameplates to determine that they have the same HP and voltage
    ratings. (Ensure that full load motor amps (FLA) do not exceed that of the inverter. (6.0 for my motor, 7.5 for the Teco))
    Hoss
  18. #4218
    Dec 2012
    390
    I have both Phase1/2 conversion and Beltdrive conversion DVDs and I have a couple of questions. The answers may be buried somewhere in this thread, but I couldn't find them in a search.
    Which size belt do I use for the 2-speed quill belt drive?
    Which size pulleys do I use for the Y-axis motor when it is mounted at the back and which size belt?
  19. #4219
    Quote Originally Posted by Stigoe View Post
    From the G0704 quill belt drive info.txt
    The timing pulley version uses a 75 tooth 3/8 inch wide XL timing belt.
    The v-belt version uses a 3L150 fractional HP belt. ( Note: a 2L150 could be used also)
    For the rear Y I used a pair of 25 tooth XL pulleys with a 77 tooth XL belt.
    You can use any pulley size or type you wish, this belt length calc will help you determine the length, use 5.188 for the center distance, doesn't have to be exact, there's plenty of adjustment + or -.
    SDP/SI
    you can email me here if you have more questions. [email protected]
    Hoss
  20. #4220
    Dec 2012
    390
    Thanks, Hoss!
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
