586,655 active members*
3,001 visitors online*
Thread: Hoss's G0704
Page 289 of 344 189239279287288289290291299339
Results 5,761 to 5,780 of 6871
  1. #5761
    Re: Hoss's G0704
    A new PDB version is printing right now that addresses the possible binding lacl brought up, this one is much more on center so should lift straight up like the PDB 2, about as tall as the first one but doesn't angle so far forward and has a different lever and cylinder mount, same ratio but needs 4+ stroke.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #5762
    Feb 2004
    1311
    Re: Hoss's G0704
    Hoss, it seems once you get into the 4" stroke range that this could be used manually with a lever too. Perhaps a phase 1 manual and Phase 2 pneumatic drawbar?
    cheers,
    Michael
    Reelsmith, Angling Historian, and Author of "The Reelsmith's Primer"
    www.EclecticAngler.com | www.ReelLinesPress.com
  3. #5763
    Re: Hoss's G0704
    Quote Originally Posted by mhackney View Post
    cheers,
    Michael
    Hmmm, something to think about.
    There have been a couple manual leverage ones done on the Tormach.
    This is using 5-600 lbs from the air cylinder with the lever now but maybe make a version that uses a cheater bar of sorts the user can make as long as they'd need and so it's removable and out of the way.
    The MAD on steroids.
    We're on it, something to do tomorrow while parts are printing, thanks Michael!
    Hoss
  4. #5764
    Feb 2004
    1311
    Re: Hoss's G0704
    I'm already thinking this would be nice scaled down for my X2. I don't want to make the investment for a full PDB but something like this would be just the ticket.
    cheers,
    Michael
  5. #5765
    Re: Hoss's G0704
    Yeah what would concern me is the force on the head pulling down on the lever, I think the g0704 could handle 50 lbs or so but that might yank an X2 head off.
    But of course the X2 doesn't need as much belleville tension either, like half of what I was planning here.
    Hoss
    Edit: as I think about it I think that using just a lever by hand we'd lose the floating aspect of the scissor action of the floating design and the full force of compressing the bellevilles would be transmitted onto the spindle.
  6. #5766
    Feb 2004
    1311
    Re: Hoss's G0704
    Good point, I hadn't thought of that.
    cheers
    Michael
  7. #5767
    Feb 2012
    5
    Re: Hoss's G0704
    Hoss, the design you have there looks like it's going to put a lot of side load on the cylinder rod. It would be better if you replace the slot on the lever arm with a pivot and hinge the cylinder mounting plate centrally so it self-aligns with the force on the lever arm through the range of motion. Just a thought.
  8. #5768
    Re: Hoss's G0704
    Quote Originally Posted by Kibo View Post
    That is exactly what the new version does.
    I didn't care for the friction of the lever slot so the new one has oillite bearings for the cam lever ends and the cylinder mount pivots.
    Should have the mockup finished printing today.
    Hoss
    edit: The side load wasn't of much concern as the stroke was 2 inches or less, the angle of the lever slot and the cylinder rod only varied 10 degrees and the cylinder rod is very stout. Made much more of a difference with the new long stroke version so the pivots cured that.
  9. #5769
    Re: Hoss's G0704
    Here's a quick vid of PDB 3 version 2 and a mount I made for my new P1AS.
    Hoss
    https://www.youtube.com/watch?v=mUky5Yqz86k
  10. #5770
    May 2013
    149
    Re: Hoss's G0704
    Hoss, I'm a big fan of your work, only one critique though.
    Could you start a new thread please? 480 pages, too much!
    Wisdom results from foolishness!
  11. #5771
    Re: Hoss's G0704
    Can't break records that way. oh I find searching 2 threads easier than 20 spread out all over anyway.
    Hoss
  12. #5772
    Jul 2008
    340
    Re: Hoss's G0704
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Not to mention the countless number of folks who have marked the thread as one of their favorites and have monitoring enabled.
    -Freeman
    CRP-4848 CNC Router, CNC G0463 (Sieg X3) Mill, 9"x20" HF CNC Lathe (current project)
  13. #5773
    Aug 2012
    23
    Re: Hoss's G0704
    Hi Folks. I've been away awhile, and I see I've some catching up to do. I'm re-starting my stalled CNC project, and need to decide which mill to get.
    I've been planning on getting the G0704 version of this mill, but I see the PM BF25 has a BLDC motor and belt drive standard. I presume the Grizzly still has the plastic gears. How is that new BLDC motor working out and is it worth the extra cost (1600 vs 1300)?
    Are there any other differences that I should be concerned about??
    Thanks to Hoss and everyone else here who have made a community for this CNC project, it is a great help.
    Thanks, Alan
  14. #5774
    Re: Hoss's G0704
    Welcome back Alan,
    The pm25 with the bldc is a relatively new offering, haven't read anyone here yet with a review of one, don't know if they've shipped any yet, last word was PM was changing suppliers for the third time.
    Best bet would be to contact them directly for news.
    Hoss
  15. #5775
    Aug 2012
    23
    Re: Hoss's G0704
    OK, Thanks Hoss. And thanks for the Phase 3 updates to the DVD set I purchased awhile back, very nice!!
    I'm not quite ready for the mill purchase yet so I'll watch awhile. I prefer a really good motor, had bad motor problems on the G0516 lathe, ended up using a monster DC treadmill motor and SCR driver there. Still have the last new Grizzly motor in the box, had refitted it by the time it arrived. Have been reading through the G0516 motor problems on here from the early days. I also want to do synchronized tapping eventually and the BLDC might make that easier, one less encoder to add. So buying a better motor from the start is appealing, though buying it cheaper and upgrading with 1100W BLDC has some appeal as well, though it is yet another project.
    Looking forward to hearing from those with the new PM25. Especially those putting phase 3 dual-nut ballscrews on them.
  16. #5776
    Re: Hoss's G0704
    The PDB 3 ver.2 fits nicely on the mill, very happy with the balance with the air cylinder on the mockup even as huge as it is.
    Going shopping again for a 2.5 inch bore cylinder, this one is a tad on the overkill side now that it's seen in person.
    Time to start making some chips.
    Hoss
    https://www.youtube.com/watch?v=j9-W_IsQwAc
    Attached Thumbnails Attached Thumbnails 100_5829_800x600.jpg   100_5832_800x600.jpg   100_5837_800x600.jpg
  17. #5777
    Nov 2009
    4415
    Re: Hoss's G0704
    Hoss, @ 80psi, if you are generating 3300lbs of force, is the arm or additional leverage necessary? I wouldnt think so.
    A lazy man does it twice.
  18. #5778
    Re: Hoss's G0704
    Quote Originally Posted by Fastest1 View Post
    3300 lbs is with the leverage, the 80mm cylinder puts out about 600 lbs (@80psi) x 5.5:1 leverage ratio = 3300, on paper anyway.
    Hoss
  19. #5779
    Re: Hoss's G0704
    Snagged a Fabco air cylinder on Ebay for $25, it's a 2.5 in. bore, 4 in. stroke pancake type (G-521-X)
    This is what I'd use as the minimum for the PDB which should be good for what I used before successfully with no pullout on the 0704, about 1500-1800 lbs holding force.
    I can however run at much higher minimum pressure with the compressor I have but I'll test at 80-90 psi first to see if this works as expected.
    Don't go rushing to buy cylinders just yet, you might wind up with extras like me.
    Cylinders of this size aren't that expensive even new so be patient.
    Hoss
  20. #5780
    Nov 2012
    220
    Re: Hoss's G0704
    Hey Hoss, have you seen the lever drawbar on the Novakon Pulsar? That seems like a good solution for people with no interest in an ATC. I have been thinking about something like that for my BF20. I would be curious to see you design a version of that...you are faster than me
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
