586,075 active members*
3,982 visitors online*
Thread: Hoss's G0704
Page 301 of 344 201251291299300301302303311
Results 6,001 to 6,020 of 6871
  1. #6001
    Jan 2013
    630
    Re: Hoss's G0704
    Hoss,
    Just some information for you to add to the pile for the G0704. I killed the motor controller on my BF20 as you may have seen and have currently started working on replacing it with the 1.1kw BLDC set up from Keling. The motor has a 14mm shaft on it and while researching gearing options, as I'm not ready to go belt drive just yet, I found that Grizzly has updated the G0704 with a motor that also has a 14mm output shaft. They list new gearing parts for it as v2 parts. The stock 20 tooth gear can be had with part number P0704230V2 and the key can be had with part number P0704231V2.
    I'll confirm after I receive it that the parts are correct and work with this set up. If that fails I'll probably do the 36 tooth conversion you did at one point until I am ready to go belt drive.
  2. #6002
    Re: Hoss's G0704
    Better baby it, that much power will make figgy pudding of the plastic internal gears.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  3. #6003
    Jan 2013
    630
    Re: Hoss's G0704
    If I kill them it will just make spending the money on a belt drive that much easier to justify. I want to get the new controller on and running without blowing it up like I did the last one before I worry about anything else.
  4. #6004
    Re: Hoss's G0704
    Yeah just a heads up, you might want to order a couple spare plastic ones too, I know one person that did the motor upgrade first and melted the gears first time out.
    Hoss
  5. #6005
    Jan 2013
    630
    Re: Hoss's G0704
    Ohh.. I'm sure I'll make some stupid mistake and kill them. Not as stupid as hooking the last 3 wires up to the Gecko and blowing up both the Gecko and motor control board but something almost as equally stupid.
  6. #6006
    Re: Hoss's G0704
    I checked and my C6 board works perfectly fine under Mach 3 for spindle control so my wiring is correct but still no joy from Mach 4 other than the clicking I showed before.
    I'll try some more later but enough is working in Mach 4 that I can use it to make a part I want.
    Hoss
  7. #6007
    Re: Hoss's G0704
    Bingo, got the C6 spindle control working in Mach 4, M3/M5 still does nothing so I'll have to look into that.
    Not much use if the gcode can't turn it on/off.
    Hoss
    edit, got some tips from Eric on youtube to adjust my settings so we'll try again tomorrow.
    https://www.youtube.com/watch?v=AOUfkqW1dUU
  8. #6008
    Sep 2009
    1856
    Re: Hoss's G0704
    just remove M3, M4 and M5 from your Profiles macro folder it will work then M6 does not stop things from working
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  9. #6009
    Re: Hoss's G0704
    Excellent, thanks to the tips from Eric and Daniel the C6 spindle control is working like it should now with M3/M5 and the sro% is what I think it should be now too.
    In Mach 3 it had a dro you could input a speed so the % overdrive made sense, I believe Mach 4 is going by the last S figure used for the sro% slider.
    Looks good now anyway.
    Hoss
    https://www.youtube.com/watch?v=7g_4gjZMA3g
  10. #6010
    Re: Hoss's G0704
    Mach 4 is ready to run, machined the part out of some plastic lumber and all went well, I'll show more detail during the real part run next.
    Hoss
    https://www.youtube.com/watch?v=R04AG1-Lfws
    Attached Thumbnails Attached Thumbnails DSCN0204_800x600.jpg   DSCN0207_800x600.jpg   DSCN0209_800x600.jpg
  11. #6011
    Nov 2013
    50
    Re: Hoss's G0704
    Hoss,
    That looks like the FCG pocket profile from an AR15. Is that what is/was modeled from?
    Zach
  12. #6012
    Re: Hoss's G0704
    Give that man a cigar.
    Hoss
  13. #6013
    Aug 2010
    46
    Re: Hoss's G0704
    Hoss
    A couple Mach questions
    If you have neither the software or hardware at this point..............
    Would you pick 3, or 4
    Would you use Printer port or not.
    How does Mach 4 connect to controller if not printer port. USB, Ethernet?
  14. #6014
    Re: Hoss's G0704
    Quote Originally Posted by BAR553 View Post
    Hoss
    Mach 4 can make parts right now but doesn't have much in the peripherals department yet, pendant, pokeys etc.
    I'll have a video soon showing what I can do with it.
    The printer port isn't the focus of Mach 4 far as I can tell, it will be geared more towards motion control boards like smoothstepper since many new or newish pc's don't even come with parallel ports.
    There is an ethernet SS plugin already with usb close behind.
    Software
    If starting out the ESS and Mach 4 is what I'd use but it's nice Art took the time to make the legacy parallel port plugin for folks like me with their mill already set up to use just the PP and Mach 3.
    It's enough to get the job done, the niceties will come in time.
    Hoss
  15. #6015
    Aug 2010
    46
    Re: Hoss's G0704
    Smooth Stepper, would also be a good choice?
  16. #6016
    Re: Hoss's G0704
    Yes, ESS, ethernet smoothstepper. No experience with it personally but it gets good reviews.
    Hoss
  17. #6017
    Re: Hoss's G0704
    Well here's the video showing you can make parts with Mach 4 but unfortunately I also show the E-stop works too.
    Part was 99% finished when the fixture loosened and let the part pull up into the endmill.
    No fixing this part so time to order another and make a better fixture.
    Hoss
    https://www.youtube.com/watch?v=EjNijPAfnA4
    Attached Thumbnails Attached Thumbnails DSCN0225_800x600.jpg   DSCN0227_800x600.jpg   DSCN0231_800x600.jpg
  18. #6018
    Sep 2009
    1856
    Re: Hoss's G0704
    nice work hoss look forward to the next 80% vid when you do it can you show how you did your fixture
    [SIGPIC][/SIGPIC]
  19. #6019
    Re: Hoss's G0704
    I used this jig but printed it, it'll be aluminum next time.
    AR15 80% tooling jig - STEP / IGES - 3D CAD model - GrabCAD
    Hoss
  20. #6020
    Sep 2009
    1856
    Re: Hoss's G0704
    thanks hoss
    [SIGPIC][/SIGPIC]
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
