Re: Hoss's G0704
Hi Hoss.
I think now would be a good time to tell people that any stepper over a 575 is just not needed for a 704 mill. The 575 is a really low inductance stepper so has the best speed of almost any stepper that you might want to run on a 704.
It is a 5.1A stepper that most people never run at full current and yet it still performs great.
For the Z if you want more power run a full power driver that will deliver the full 5.1A.
The China driver almost always use peak so you need to multiply that number by .707 for the RMS current.
To get full power from the 575 you need 7.2A peak.
So many people have asked for the Nema 34 Z stepper mount that I quit making the 23 which is a waste. I'm doing a test right now and I will be using the Nema 23 575 on the Z and will have it raise up and down my kids on the Z (did this before but no camera) a few time to make the point.
The best stepper ever made is the 575 Nema 23! Its cheep, has fantastic low inductance and runs well at 3.5A with no heat. At 3.5A it is really quiet too.
Just get the 575 and your done.
I ran the 575 on my Weiss 30 for the X and Y and it worked so well. The table on the 30 is exactly the same size as the small tableRF-45. I would never, unless I had them for free, run anything larger on that size mill. The 900oz Nema 34 is also great but it is a 6.1A stepper and only the largest China drive will run it at full power and it likes a little higher voltage so you have to under volt it if you stay at 50 or so volts for the 575 stepper.
All these guys running the Nema 34 on the Z are making it go slower than if they ran the 575. Well I hope I made my point.
youtube videos of the G0704 under the name arizonavideo99
