586,114 active members*
3,381 visitors online*
Thread: Hoss's G0704
Page 329 of 344 229279319327328329330331339
Results 6,561 to 6,580 of 6871
  1. #6561
    Jul 2015
    142
    Re: Hoss's G0704
    CFLBob
    could you post a pic of the enclosure when your done?
    Thank you
    Joseph
  2. #6562
    Apr 2016
    100
    Re: Hoss's G0704
    Sure.
    That's a ways off, like a few weeks or so. It's going to take me a week or more just to figure out the jigsaw puzzle. ("Where does this piece go?")
    Bob
    CNC hobbyist since 2003.
    Current CNC hardware: Sherline/A2ZCNC extended, 4 axis X/Y mill and Sherline lathe
  3. #6563
    Apr 2016
    100
    Re: Hoss's G0704
    Question for those who have gone down this path before me. Did you paint the bottom of the tray?
    I have two good coats on the inside, and a good coat on the sides. I'd think it doesn't get wet under there, but is that only if everything is perfect?
    Bob
  4. #6564
    Re: Hoss's G0704
    I didn't bother.
    If the inside had a leak and the bottom was sealed the wood would stay saturated and rot vs being able to see where the leak was and the wood could air dry.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  5. #6565
    Apr 2016
    100
    Re: Hoss's G0704
    Quote Originally Posted by hoss2006 View Post
    I didn't bother.
    Hoss
    Good point.
    That deck paint is good stuff, so thanks for the tip on that. Leaves a nice thick coat, and seems to seal well. I'm down to about 1/8 of the can, so I'll put a second coat on the outside of the 1x6s and toss it if there's any left.
    Bob
  6. #6566
    Apr 2016
    100
    Re: Hoss's G0704
    Hoss,
    Is there a 3D drawing around anywhere of the G0704 and its base, as they come from Grizzly. I really just need the overall size and shape right, so I can pull the mill off the stand and raise it a bit.
    I just did a quick 3D model of the chip tray, and I want to incorporate it into the 3D model of my shop - so I can have more confidence it all fits as I go forward. I built my shop model in '14, and just used a large rectangular block for the mill. Do any of the online sharing places have one?
    Bob
  7. #6567
    Jul 2012
    80
    Re: Hoss's G0704
    I remember seeing a model someone created somewhere on CNCZone. You would need to do some digging to find it though.
    Michael Anton
    http://manton.wikidot.com - http://laserlight.wikidot.com
  8. #6568
    Apr 2016
    100
    Re: Hoss's G0704
    Quote Originally Posted by manton View Post
    I was searching the web for models - went to Thingiverse and Grabcad, and just found a place that sells models for $20. I don't mind paying for a model, but I'd probably create one for $20. (Retired = more time than money) While I was searching for images, I found a couple that linked to here on CNCZone, but when I followed the links, there was no model.
    I don't know if it's worth spending too much time looking or just go sit down with a sketch pad and a tape measure.
  9. #6569
    Jul 2012
    80
    Re: Hoss's G0704
    In this thread: http://www.cnczone.com/forums/bencht...cam-forum.html the OP talks about having made a model. Perhaps he would share it with you.
    Michael Anton
  10. #6570
    Apr 2016
    100
    Re: Hoss's G0704
    Thanks - that's rather far beyond what I was looking for. He's taking his G0704 apart, milling off the dovetails are replacing them with linear rails. It's a complete redesign.
    Considering how popular the mill is, I thought someone had probably put up a basic model of it. If I get a decent model together, I'll share it.
    Bob
  11. #6571
    Jul 2015
    142
    Re: Hoss's G0704
    I have a question
    I have an Automation technology 1100 watt brush-less motor kit I want to know if I can put the driver in the same enclosure as the other electronics ie stepper drives, bob ect?
    Thank you
    Joseph
  12. #6572
    Mar 2012
    109
    Re: Hoss's G0704
    Quote Originally Posted by CFLBob View Post
    Here's some of the stuff I've compiled over the last few months from odd corners of the internet. Compressed with 7Zip, if you have trouble uncompressing just download it (google) its free.
    Note: The assembly files may be a bit garbled, so you're on your own for building the assembly if so. Its been a while so I'm not quite sure, but either way, enjoy!
    https://mega.nz/#!iNMCXQoA!kabF1sG3V...LmZkrR4EJm7i1o
  13. #6573
    Jun 2008
    467
    Re: Hoss's G0704
    The download requires a encryption key, any idea what it is?
    Quote Originally Posted by inthebay View Post
    Live from downtown Burbank, home of the free endless Cup-O-Joe.
    JoeyB
    A doughnut a day keeps the doctor away.
  14. #6574
    Mar 2012
    109
    Re: Hoss's G0704
    Quote Originally Posted by joeybagadonuts View Post
    JoeyB
    Odd, I tried to make it keyless.
    Regardless, if my fix didnt work, try this
    !kabF1sG3VxFZJc4fEpeUhLUG0WdcaLmZkrR4EJm7i1o
  15. #6575
    Apr 2016
    100
    Re: Hoss's G0704
    Thanks, but "Mega" won't allow me to download that without a "Decryption key". Saying "if you don't have the key, contact the creator of the link".
  16. #6576
    Mar 2012
    109
    Re: Hoss's G0704
    Read my response above, the key is !kabF1sG3VxFZJc4fEpeUhLUG0WdcaLmZkrR4EJm7i1o
  17. #6577
    Jun 2008
    467
    Re: Hoss's G0704
    Tanks
  18. #6578
    Apr 2016
    100
    Re: Hoss's G0704
    Got it from the previous response, which appeared after my response.
    Thanks!
  19. #6579
    Aug 2003
    329
    Re: Hoss's G0704
    Duplicate post
    Joescnc 4x4 R&P Router, Minimill, Minilathe, CNC Foamcutter, laser cutter, Vectric Aspire. http://makermasters.com, http://themakersguide.com
  20. #6580
    Apr 2016
    100
    Re: Hoss's G0704
    Bill -
    Can you supply some details on the motor? When you say 3phase, is that something you need a VFD for?
    Bob
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
