586,121 active members*
3,483 visitors online*
Thread: Hoss's G0704
Page 105 of 344 55595103104105106107115155205
Results 2,081 to 2,100 of 6871
  1. #2081
    Quote Originally Posted by mwood3 View Post
    So from this, I gather you must place the sub at the end of the program? not so conveinient for multiple programs running the same sub... is this common with other cnc controllers or am i misunderstanding?
    Copy and paste isn't that hard to do.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #2082
    Jun 2008
    614
    Quote Originally Posted by hoss2006 View Post
    Hoss
    yeah yeah...your right, just have to use a different mind set...guess im not too old to be set in my ways anyhow
    http://www.g0704.blogspot.com/
  3. #2083
    Never too late to teach an old dog a new trick.
    Hoss
  4. #2084
    I made a new base for the ATC that moves it over another inch so now a tool change
    is only a half inch off the X home switch.
    The ATC home switch is installed too and I mounted the ATC where it belongs.
    Got one tool change done before the camera battery died.
    Now I need to make a bunch of adapters for my tools so I can use the ER25, boring head, facemill, tension/compression holder, etc.
    Don't forget the chip cover too.
    Hoss
    [ame=http://www.youtube.com/watch?v=GYn9oLF_uxw]G0704 ATC 4 1st Tool Change - YouTube[/ame]
  5. #2085
    Dec 2010
    201
    Uh... Stupid questions here from a guy about to drive to Springfield, and then send Hoss some bucks...
    Anyone figure out a fourth axis? Which table did you use? Because bogie wants a fourth axis...
    And the whole concept is continually looking way too cool.
  6. #2086
    The 6 incher I used not too long ago for the 5th axis/head extension is one I plan to
    get again to make a 4th axis out of, the little 4 incher I have just looks like a toy on this mill.
    Hoss
  7. #2087
    Ok, new battery and here's some tool changes.
    Lovin this ATC, took about ten minutes to set it up on the mill and edit the macro to get it working.
    Piece of cake.
    Thinking of making a monster toolrack now for it.
    We'll see what it'll hold.
    Hoss
    [ame=http://www.youtube.com/watch?v=YVpH8blWn28]G0704 ATC 4 Tool Changes - YouTube[/ame]
    Attached Thumbnails Attached Thumbnails 102311 029_800x600.jpg   102311 030_800x600.jpg
  8. #2088
    Apr 2004
    128
    Tool Change
    Hi Hoss,
    As usual that's a fantastic piece of work !!!!
    Sean
  9. #2089
    Quote Originally Posted by duzallcnc View Post
    Hi Hoss,
    Sean
    Thanks,
    the big rack is drawn and ready to machine, holds 10 tools so I think I'll make one
    just to make sure it fits.
    Hoss
  10. #2090
    Nov 2009
    4415
    Are you going to implement a touch plate for ATLO? That would be cool too.
  11. #2091
    Yeah I'll get my probing running again when the console is redone, I don't have any spare inputs left with this temp setup.
    Hoss
  12. #2092
    Quote Originally Posted by Fastest1 View Post
    Rather than using my semisolid tool setter, I'll be making a spring loaded tool setter in this vein.
    Tool Setter
    The Tormach one is just nut$$$.
    Hoss
  13. #2093
    Dec 2006
    53
    Looking good!
    Looks great Hoss, tool change speed is comparable to one of the machines I setup on at work, fadal vmc4020
    Mike
  14. #2094
    Quote Originally Posted by gun_mike View Post
    Mike
    Thanks, I can shave a little more off of her yet.
    The axis' aren't running full bore.
    Hoss
  15. #2095
    Nov 2009
    4415
    Tool Setter
    Hoss
    I am guessing yours will connect with your BOB to interface within Mach. That is a nice design but rather than have the plunger recessed, if it was overlapping the cylinder it would eliminate the chips intruding into the switch. Swarf and coolant free.
  16. #2096
    I agree, I didn't say I was going to make that exact one, It's just an example of a spring loaded one.
    More like the Tormach but MUCH cheaper.
    Hoss
  17. #2097
    Oct 2010
    266
    Someone at tormach was on some good drugs when they came up with the price for that
  18. #2098
    You do get that nice carrying case with it.
    Hoss
  19. #2099
    Oct 2010
    266
    Well I was gonna get it but it says they have to charge an extra $5 for insurance, guess the profit margin on it can't support them covering it lol.
    So how bout a duplicate of your atc on the other side of the table as well so you have two racks, doable?
  20. #2100
    Well, sure, could do it but I'd like to be able to have a long piece of stock overhang
    the end of one side when needed.
    6,8 or 10 tools are plenty to get a job done.
    I do have the 12-16 tool atc waiting in the wings though.
    Hoss
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
