586,246 active members*
3,585 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > machining holes in hardened steel
Results 1 to 11 of 11
    Aug 2007
    i have some .360 holes that need to be reamed to .371. the material is case hardened 8620. around 58-60 rockwell. the problem is the holes were supposed to be plugged at the heat treater but were not. any suggestions on a method to enlarge these holes. finish tolerance is +/- .0005.
    Aug 2010
    Question
    Blind or thru? To what depth? Is .360 the actual hole size or pre-cased size?
    Regards
    The Manufacturing Reliquary
    http://cmailco.wordpress.com/
    solid carbide reamer or interpolate
    interpolation would probably produce the best results with that kind of hardness
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    May 2010
    Do a search for Hi-Roc drills. They work great in a very rigid setup on 58-60.
    John
    Jul 2010
    Jig grinding, pure and simple.
    Aug 2007
    the pieces are 1.2" thick and they are thru holes. .360 is the actual hole size.
    Aug 2007
    pieces are 1.25" thick. holes are thru holes.
    May 2010
    Wire edm would be an option as well.
    John
    Aug 2010
    A carbide reamer is probably going to be your least expensive option for this.
    20-30 SFM, .003-.004 in/rev.
    Sep 2010
    With that kind of tolerance, I would drop into the hole with a carbide end mill and use a circle mill path (or interpolation move), but sneak up on the wall with wear comp. (I would go with multi-passes to get rid of deflection and taper...i've had the best luck with light, quick cuts). You could probably get away with using a 1/4 EM - if there is enough flute (1/2 depth?)
    Aug 2010
    Talking
    By the way, that recommendation is based on actual experience reaming hardened steels in this range. And, HSS actually works quite well in materials up to 50 HRC. The amount of leave (.011) is ideal for reaming in this situation.
  1. Replies: 9
    Last Post: 10-16-2019, 05:43 AM
  2. Are Ballscrews Hardened Steel or not????
    By Hellbringer in forum Benchtop Machines
    Last Post: 02-26-2008, 07:15 AM
  3. Machining Hardened Steel Shaft
    By jimbobbus3 in forum MetalWork Discussion
    Last Post: 11-10-2006, 04:41 AM
  4. Cutting Hardened Steel
    By Smackre in forum Waterjet General Topics
    Last Post: 02-08-2006, 08:12 PM
  5. Drilling hardened steel shaft
    By Zephrant in forum Uncategorised MetalWorking Machines
    Last Post: 06-13-2003, 09:42 PM
