586,485 active members*
2,550 visitors online*
    Nov 2007
    197
    best aluminum grade for cutting
    as i discovered with stainless, some grades cut better than others. In general the sheet stock grade (321 i believe?) left a pretty nasty edge compared to 304.
    i have a job coming up in aluminum and i haven't cut that yet. What grade would you recommend? its going to be 1/8" sheeting.
    choices being
    1100
    5052 (says easy to weld according to McMaster)
    6061
    Jun 2007
    268
    I've cut 1/8th 5052 alum with decent edges and no dross, 1250 Hypertherm, fine cut consumables @40 amp, 79 arc voltage, 145 ipm...
    EDD
  1. Cutting Aluminum...HELP!!!
    By wilson248 in forum MetalWork Discussion
    Last Post: 03-16-2010, 03:38 AM
  2. Cutting .250+ Aluminum
    By Drools in forum DIY CNC Router Table Machines
    Last Post: 06-04-2009, 06:28 PM
  3. What grade aluminum do you guys use? And where do you get it?
    By slickrick in forum DIY CNC Router Table Machines
    Last Post: 09-29-2008, 01:02 PM
  4. Replies: 0
    Last Post: 06-07-2008, 03:15 PM
  5. Aluminum Cutting
    By Tazzer in forum DIY CNC Router Table Machines
    Last Post: 07-29-2003, 06:09 AM
