586,072 active members*
4,369 visitors online*
Results 1 to 6 of 6
    Apr 2007
    32
    Mori Seiki AL 2 Fanuc System 10TE
    I am getting an Alarm Code "SV013 X Improper V-Ready Off". Book says Check for a 100vac between terminal 3 and 4. Check fuse breaker is not tripped. Can anyone help me out here...where are terminal 3 an4? Which fuse breaker and where is it? Also what next if I do or do not have 100 vac?
    Feb 2009
    6028
    wow, AL2, that brings back some stories...
    Anyway, there is a re-settable breaker in the drive. It has a pushbutton on it to re-set it. It's actually a contactor with an overload realy if I remember correctly, but whatever. Check that.
    Apr 2007
    32
    what do you mean "in the drive"? Where?
    Feb 2009
    6028
    Electrical cabinet, X axis servo unit. You can also fry yourself if you don't know what you are doing, so be careful. Drives store energy for a while even if the power is off.
    Apr 2007
    32
    how do I tell what is the X axis servo unit? Sorry for the lack of knowledge.
    Aug 2008
    53
    Quote Originally Posted by krfrea View Post
    If you look at the grey Honda connector that is connected to the drive, it should have an X on it for X axis. It plugs in vertically from the bottom up.
  1. help MORI SEIKI MV- 40 FANUC MF-M4
    By vladimir1409 in forum Fanuc
    Last Post: 11-19-2023, 07:56 AM
  2. FANUC SYSTEM 10TE-F SERVO PROBLEM
    By tano in forum Fanuc
    Last Post: 07-07-2010, 11:59 PM
  3. Mori Seiki SL-20 Fanuc 10T
    By premier_industr in forum Fanuc
    Last Post: 12-15-2009, 02:55 PM
  4. mori seiki SL-3A lathe w/fanuc 6
    By enrique flores in forum Mori Seiki lathes
    Last Post: 07-16-2009, 10:24 PM
  5. Mori Seiki MF-T6 System Variables
    By EvilScooby in forum Uncategorised CAM Discussion
    Last Post: 06-13-2003, 01:32 AM
