586,103 active members*
3,214 visitors online*
    Jul 2007
    8
    Help choosing suitable milling machine
    Hi all,
    We own a small workshop in Cairo, Egypt that's based entirely on conventional machines. Lately, we've faced some difficulties doing some parts using our conventional machines, and had to turn down a few jobs.
    So we're thinking of investing in a CNC milling machine to use with these types of jobs.
    Generally we work with 1-mm thick Low-carbon steel, and sometimes aluminum.
    We have already determined all of our machine specifications, but couldn't determine the suitable horsepower that would be needed for the spindle motor.
    So could anybody please suggested how much hP would at least be needed for our applications ?
    Also, if we buy a used machine with a max. RPM of 6,000, would that be ok ?
    Thanks !
    Mar 2006
    2712
    An old "rule of thumb": 1 cubic inch of steel per minute requires 1 horsepower. That is for mild steel, not hardened tool steel. LOL
    Dick Z
    DZASTR
    Mar 2009
    1982
    Are You sure, You need milling technology? Isn't it metal sheet?
    Jul 2007
    8
    Quote Originally Posted by RICHARD ZASTROW View Post
    Dick Z
    Thanks for the tip Richard, I think mild steel & low carbon steel are one and the same, aren't they ?
    Quote Originally Posted by Algirdas View Post
    It's not suitable for sheet metal forming machines, the workpiece consists of a hollow elliptical shape, that has a thickness of 1mm. The milling has to be done on 1 side of the ellipse only.
  1. Replies: 4
    Last Post: 06-28-2009, 02:06 AM
  2. Is this machine suitable
    By ball99 in forum Waterjet General Topics
    Last Post: 08-18-2008, 02:04 AM
  3. Is the Syil / Sieg X3 suitable for climb milling?
    By Ed from NY in forum Syil Products
    Last Post: 08-30-2006, 04:10 PM
  4. Need a suitable machine
    By Moesian in forum Mechanical Calculations/Engineering Design
    Last Post: 08-14-2005, 05:49 PM
  5. Are Linear bearing setups suitable for Milling Machines??????.
    By Moondog in forum Uncategorised MetalWorking Machines
    Last Post: 11-02-2004, 03:33 PM
