586,103 active members*
3,703 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Difference between Fanuc 0i-MC and Fanuc 0i-MD
Results 1 to 13 of 13
    Jun 2010
    30
    We are planning to buy a new machining center from Korea. Initially the supplier offered Fanuc 0i-MC control with the machine but now he has offered Fanuc 0i-MD control with the machine at an extra cost of US $ 5000. What is the difference between the two models. Is it worth to pay this amount for new model.
    humak16
    Dec 2003
    24221
    The 0 series is a fairly old control, but still popular, I though the 0i was a later version.
    I have integrated a few 0's, but not the i series since switching to Mits.
    Al.
    Albert E.
    Dec 2006
    51
    The 0iMD is Fanucs Lastest addition to it's Lowcost control product line.
    It is enhanced with new features over the previous 0iMC product.
    http://www.fanucamerica.com/portal/p...R_06222010.pdf
    http://www.fanucamerica.com/portal/p..._Photo_4x4.jpg
    The newly enhanced features to the 0i-D include:
     Max total controlled axis increased to 8 axes milling model
     Al Contour Control II (milling model) uses a state-of-the-art ultra high-speed
    processor allowing high-speed machining of complex free form parts which are
    programmed in continuous small block segments
     Nano Smoothing (milling model) smooths surfaces by converting small block
    segment programs into smooth NURB surfaces in real time
     Jerk Control (milling model) for smooth acceleration with less machine jerking
     Enhanced Tool Management (milling & turning models)
     Retraction for Rigid Tapping (turning model) for cycle time reduction
    Feb 2009
    6028
    Our new Mori Dura verticals all came with the Oi-D. From what I can tell, it just allows more options down the road. We originally ordered them, was supposed to be the C control, and D's showed up. Was also supposed to be Mori Mapps III panels, and MAPS IV showed up. No price increase. There was in the last few months a price increase due to the weak dollar. Someone is playing bait and switch I think.
    Jun 2005
    232
    One wll handle a 4th axis and the other won't
    Tim
    Oct 2011
    gibbs post
    Any chance of anyone having a gibbs post processor for this control?? Fanuc Oi-MD on a new Bridgeport/Hardinge VMC
    Aug 2011
    2517
    any Fanuc mill post would do. there is surely something compatible supplied with the program.
    anyway if you still need help you probably should ask this question in the Gibbs Forum
    GibbsCAM - CNCzone.com-The Largest Machinist Community on the net!
    Mar 2010
    The 0i-MD is the latest generation of the FANUC Series 0 control. Since the FANUC part program format is very consistent over the years, any FANUC post should work.
    The 0i-MD includes many standard features, similar to the 0i-MC, but there are some new features including:
    - Ethernet port as standard
    - nano-interpolation for smoother surface finish
    There are some new advanced options on the 0i-MD that were not available on the 0i-MC including
    - nano smoothing
    - AICC II
    Attached Files Attached Files
    Jun 2010
    161
    The Series 0i-A/B/C were derived from the Series 16 based family of CNC controls while the 0i-D was derived from the Series 30i based family of CNC controls. There are enough gotchas when going to a 0i-D that I highly recommend you consult the 0i-MD Machining Center User's Manual, B-64304EN-2, Appendix B "Differences from Series 0i-C" to see if any apply to you.
    There are differences in some programming features (e.g. Programmable Parameter Input is G10 L50 in 0i-C while it is G10 L52 in 0i-D). They divide up the differences in 38 subsections so have a look for yourself to make the transition easier.
    Mar 2010
    CNC2149 is correct about the 0i-D being closer to the Series 30i. Attached is the appendix he referred to if it helps.
    Apr 2006
    125
    Thanks for the link.
    Big differences. Totally different control by the looks of it.
    Mar 2010
    Yes! There is a perception that a FANUC 0i is an old control. But the 0i-D controls is a very new control using the very latest technology for performance, precision and reliability. The features nanometer resolution for precision and surface finish quality and 28-years mean-time-between-failures. There are over 200 premium features standard in the control which makes it very competitive in the commodity machine market.
    Mar 2005
    816
    Ok, so what are the 0i Model A and B controls like?
  1. GE Fanuc & FANUC proprietary posts
    By cncadmin in forum Fanuc
    Last Post: 01-12-2022, 07:33 PM
  2. Replies: 5
    Last Post: 03-09-2011, 04:11 PM
  3. What is the difference between Fanuc and Yasnac?
    By horst007 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-05-2007, 03:19 AM
  4. Difference b/w Fanuc 0iA & 0iM
    By eng8248 in forum Fanuc
    Last Post: 01-31-2007, 01:29 AM
