586,315 active members*
3,269 visitors online*
Results 1 to 9 of 9
    Apr 2008
    14
    Bridgeport EZ Path
    We moved this lathe and can not get the computer started. We turn on and ge the message waiting for DOS. We have a later Bridgeport. Info in the later Manual says to hold Control, Alt, Delete. Any one know if this is the way to start DOS in the EZ Path.
    Thanks,
    EC
    166
    What I would do is reload the machine using the original floppy disc that came with the machine. With the machine off put the disc in the floppy drive. Turn the machine on and follow the on screen instructions to reload the software. If that doesn't work then something bigger may be wrong.
    Apr 2008
    14
    Bridgeport EZ Path
    Bret
    Thanks for the reply. We used the backup disk but keep getting the message waiting for DOS. I'll try the BPT guys Monday if I don't get anymore replies.
    166
    If you have checked all the plugs that plug into the pc parts in the back, then it could be the drive went bad. I seem to remember that the old ones may have come with a standard hard disc drive. The newer ones came with a flash memory drive because the hold up better. Any way you look at it your drive may be bad or the cable is just loose. If not the bridgeport guy may need to fix it.
    Jul 2007
    45
    Control Alt Delete is the software equivalent of pressing the reset button or turning the machine off then on. It just reboots the machine and does not normally get to a DOS prompt on the EZ-Path.
    I have a PowerPath and an Ez-Path II. When the machine is started the first screen should stay there for a couple of seconds allowing for the Delete key to be pressed to enter the BIOS. After that a screen should come up and on that screen it should say starting MsDos somewhere. It should then say “opening BMDC.bin” These go by quickly so may take restarting a couple of times to see them. If you see these messages then the autoexec.bat program is executing on C:\. On my Ez-Path II the autoexec.bat program then switches directories to the C:\EzPath directory and executes the EZ.bat batch program etc.
    If you see the above messages if should mean the hard drive is physically OK so that could be eliminated. As bret4 said, it would have been nice if the backup disk would have reinstalled the software; and hopefully preserved the existing parameters.
    Nov 2005
    1468
    I moved my miller and had a similar problem booting from the floppy... turns out the boot disk was partialy ejected- the enclosure door was pressing against the eject button just enough to partialy eject the disk when the door was closed, when you opened the door it re-seated itself. Took me a whole day to find this out!
    Just a thought
    Nov 2010
    no boot disk
    We have a '95 Bridgeport ez path lathe that acts like the hard drive is not working. The screen message ask to insert the boot disk, which was not received when we purchased the machine. Is there anywhere to get a boot disk for this machine? Any good repair mechanics for these machines?
    thanks,
    David
    Sep 2006
    251
    DLBEE,
    Try DB - 2 from Warren, Mi.
    Just a good ol' boy, never meanin' no harm.
    Joe
    Jul 2007
    37
    Call Quantum Machine, certified B'port Service, 303-503-9677, they are great to deal with
  1. bridgeport ez path lathe
    By sempe0 in forum Want To Buy...Need help!
    Last Post: 03-11-2010, 06:01 PM
  2. Bridgeport EZ-Path motherboard
    By stein530 in forum Bridgeport / Hardinge Mills
    Last Post: 07-30-2009, 01:56 PM
  3. Bridgeport Power Path
    By elsie215 in forum Bridgeport / Hardinge Mills
    Last Post: 06-18-2009, 08:11 PM
  4. Bridgeport lathe cnc ez path
    By J Hailmann in forum Bridgeport / Hardinge Mills
    Last Post: 06-05-2009, 12:27 AM
  5. EZ Path Bridgeport lathe
    By ruger2 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-31-2007, 07:33 PM
