Originally Posted by
dghele
Hi guys,
I know is an old post but is related with drip feed so... I will ned your help and guidnes. I've read very carefully the previous posts and I will describe below all the information about my machine / issue.
I own a Deckel Maho 3Axis mill with Fanuc 10M. The machine had in a past a device with 3 conectors: 1 x power supply, 1 x rj45 wire connected to start and stop buton on the console and one rj45 connected to machine serial port.Unfortuntly I do not have additional information about device installed but I just supose that was used for drip feed.
Now after some investigation I found out that information from one manual to another is different and is getting confusing.
Acording to line 2001(attached pic) machine is using FS3 interface and I've searched in ladder for G012.3 but I could not find any. The closest was G012.2 representing MD4 but I do not know what actualy means MD4.
As additional information: PMC main board model A16B-1010-0040/12E with eprom version 1020(1020C on boot display). I attached also parameter from 20,21,22,23.
Now I'm asking you, what options do I have for a drip feed? An eprom upgrade?
I have a propper Programmer Dataman 48Pro2 (with a VPP range 0..26V/1A) so I can write some Eproms if somoane will asist me with the hex files.(user CNC2149 wrote that 1021version will allow drip feed).
