Hi all,
I have a small technical question I haven’t been able to answer satisfactorily by Googling :
Suppose I want to drive a milling machine axis using two ballscrews, each with its own stepper motor. Do I need two stepper motor controllers, or can I just wire both motors to the same controller ?
The motors would of course by identical. The ones I have in mind draw 2A, and I have a 5A-capable controller on hand, but I’ve never heard of anyone driving two motors from one controller. Do you know of any reason I shouldn’t ?
My basis for believing this could work is that some bipolar motors have four stator windings instead of 2, and you can wire them in parallel. I’d be doing the same thing except the windings wouldn’t all be in the same motor.
My reason for trying to do this isn't so much saving money (though I wouldn't spit on that ) it has more to do with safety : I wouldn't want a computer bug to cause one motor to move without the other, as this could destroy my machine tool. By wiring both motors to the same controller, I suppose the only way this accident could happen would be if one of the motors failed... but if it did, the other one would get all the current and die too, so it'd be "safe"
What do you think ?
Thanks for your time !
Jean
