586,096 active members*
3,112 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Opening a .dwg file ??
    Oct 2006
    157
    Can you open , with bobcadcam V21, a .dwg file that was created in autocad?
    Jun 2008
    1838
    Quote Originally Posted by AirChunk View Post
    Yes, you should be able to open it OK, only thing that may be a problem is what version of Autocad it is, if it`s an older one should be OK but possible a newer version might not work.
    DXF files are usually easiest to open if you can get the file in that format.
    Regards
    Rob
    :rainfro::rainfro::rainfro:
    Feb 2007
    505
    Smile dwg to dxf converter
    I have never try them but if everything else fail , you might want to try this.
    http://www.freedownloadscenter.com/M..._Download.html
    Dec 2008
    4548
    If V21 WILL open dwg's, just not the latest versions, I would use Autodesk's TrueView 2010. It will have a conversion command to convert them into an earlier version...
    DesignReview 2010 will also add some very cool annotation and info sharing to the drawings also...
    Both free from Autodesk...
  1. New to bobcad v22 help opening file?
    By Coolster in forum BobCad-Cam
    Last Post: 07-02-2018, 09:01 AM
  2. opening a mastercam x file on v9
    By drewmeister in forum Mastercam
    Last Post: 12-16-2008, 12:54 AM
  3. Opening CDR file extension.
    By terry32506 in forum Uncategorised CAM Discussion
    Last Post: 03-02-2008, 05:53 PM
  4. Opening ProE (prt) File
    By allennella in forum Mastercam
    Last Post: 10-11-2007, 02:19 AM
  5. Problem Opening Solidworks File
    By skinnekid in forum Solidworks
    Last Post: 09-25-2005, 12:33 AM
