586,776 active members*
8,760 visitors online*
Results 1 to 19 of 19
    Dec 2004
    9
    CNC Conversion?
    Hey fellas,
    I was wondering if one type of bridgeport (or other brand names) or year was better for converting to cnc over another. I have heard that a bridgeport boss that has been put out of use b/c of out of date control systems are good and cheap. I just can't understand the difference between the boss and a manual mill. How much slack can a mill have in it and still be accurate for a cnc conversion? The largest stepper motors I can find are 1200 oz and I was thinking about using gear reduction 3:1. Will this provide for a fast mill with lots of power or just kind of a getrdone thing. I not expecting a machining center but would like for things to run pretty smooth. Thanks for your help. Oh yeagh do you power the z axis from the quill or from the knee feed?
    Chris
    Aug 2004
    2849
    The problem with the Bridgeport Boss..is the cost to replace / repair the controller....so people chuck them. If you're looking for total CNC....then you need to control both the quill and da knee.
    Steppers in the 1200 oz-in range should suffice.
    The biggest benefit of picking a Boss over a manual mill...is that the Boss already has ballscrews.....it's CNC enabled. Other stuff has been done to the Boss to reduce friction....
    Dec 2004
    9
    Hey Viper,
    I know ballscrews will have less backlash but will the standard feed screws work for a cnc mill, or would I be compromising accuracy? Is it pretty straight forward to replace the standard feed screws with ball screws? I dont understand why you need to have a quill feed and a knee feed. There both just moving the z axis, can you give some detail on this. I am going to do a complete retrofit on the mill (power supply, driver, steppers, ect) so the boss and all its drive components will be taken off. How big are the boss series compared to the standard bridgeports, they looked huge in the pictures. Thanks again for the help!
    Mar 2004
    1543
    I guess you could use standard acme screws for CNC but it would be a HUGE compromise. Way more backlash, and its not constant- more in the middle- and you'd need bigger seteppers because of more friction. (My bridgy has 40 thou backlash in the middle and less than 5 on the ends)
    Normally you'd CNC the quill, not the knee because it takes a huge stepper/servo to move the knee. Again, a boss is all set up for CNC on the quill.
    There's no reason you can't replace the standard acme screws with ball screws but it might be expensive.
    Boss series 1 is basically like a 2J manual bridgeport with a beefier table. SeriesII and III get to be pretty big machines. I just seen a series 1 go for $250 a couple weeks ago - dead control of course.
    Karl
    Aug 2004
    2849
    $250....I'd take one for that price....tack on another $1200 for shipping it....sounds like a bargain.
    Dec 2004
    9
    Would a cheap boss be wore out?
    Hey Again,
    Thanks Karl and Viper for the info! I never have touched and will never have the money to buy a new bridgeport; do they come from the factory with backlash or is it just from years of wear. Can a boss still be used as a manual mill or is it totally cnc only? If I found a boss 1 for a good price and it was pretty old, would it still be usable? Another words is it likely that it would be woreout from years of cnc use or do they usually stay pretty tight? Thanks again fellas, your help is very appreciated. I am from alabama and machine shops are becoming scarce, I have been to 4 auctions around here local in the past 6 months. Most of the "machinist" left are what I call handle turners. They sit at the same machine every day doing the same job and are not very skilled at thinking outside the box. I am a welder and trying to pick up a few skills here and there. I would like to find me some old timer and sit him down in my shop for about a month and let him talk my ears off. Does anyone have one for sale or loan? :wee:
    Chris
    Dec 2004
    293
    Chris, the cheapest way to go is to get a series 2 Boss and replace the controls. Keep the steppers.The screws are likely to be in pretty good shape.
    Each machine is going to be very different with respect to wear. I think my machine was originally and Army machine that got surplussed out. The original paint is O.D. It was doing a lot of drilling only by the looks of the chips stuck in the knee. So, the ways are pretty good. The head is a little screwed up.
    I've not done the Boss thing. But from what I've seen over the past few years, that is what I would do next.
    I'm in the middle of a Series I 2J conversion now. It has been a lot of work. If I had just done the Series 2 Boss I'd be done. Shop around. Great deals are out there. You'll be surprised over the next few months how many machines you'll find within driving distance of you. Maybe a long drive. Atlanta too far? Rent a truck and a car trailer.
    But.....if cash flow is the issue, like it was for me, chipping away at a Series I conversion might be the way to go. OBTW, I am using servo motors.
    I have some old but never been used Reliance Micro 100 series motors. Nema 34. E-Bay find. I just got the quill under power at only 33V and it can over come the quill lock with ease. My final voltage will be 56V. It's rated at 100V. So I was worried about the torque at a lower voltage but, no problem. Lesson being there are a wide range of motors that will work.
    If you haven't heard of them, check out www.geckodrive.com or www.rutex.com
    Both are good makers of stepper and servo drives.
    With a PC and some of their drives you have a pretty easy replacement for the stock controls on any of the Boss machines.
    -jd
    Dec 2004
    9
    Hey JD,
    Thanks for the info! I am pretty comfortable with the drives, pc, and steppers. I have been running a torchmate 3 for a little while and getting ready to build a 4 x8 plasma table. I was unclear on which machine best suited overhauling weather a manual mill or a previous cnc mill and almost everone says a previous cnc mill. I will start hunting one down, I have seen a few on ebay go for less than 500 dollars that was within a few hours of driving. The transporting wouldnt be a problem we have tractor trailer rigs but I figure a flat bed gooseneck would be fine. I figure a old cnc mill would weight around 5000 at the best? I noticed you said a series 2 over a series 1. Is it a reason for that? Thanks a million yall!
    Chris
    Apr 2005
    345
    I recently got two Boss 5's that were "supposed" to be ready to run. Well they didn't and I will be retrofitting one with (most likely) gecko's and Mach 2. I would consider selling the other machine or control parts from the one I gut. The problem appears to only be bad drive transistors........but after seeing and researching Mach 2 and geckos, I am more excited about going that route anyway.
    Nov 2004
    3028
    The transistors are the most comon things to go. Anyone that has one of these machines keeps a box on 2N6547 transistors. BUT, having worked on these for 23 years, there are ways to make these drives a LOT more reliable. I have people that now have run for years without blowing one.
    George
    Feb 2005
    15
    Hey guys check out Excitron drives. I have not bought them yet; but they have some real torque monsters though. Rated in Inch pounds not Oz. inch. I would recommend trying the knee for a Z axis. It is much more rigid and has less slop than the average worn quill. Rig a counter balance by using an air or nitrogen cylinder under the knee and you should reduce the power to drive to a resonable level. I have not tried it yet but it is what I plan to do on an old Hardinge horizontal knee mill we have at work. The air would obviously be cheaper and you could easily adjust the pressure with a regulator to what worked best. Just enough to equal out the load so the screw turns the same torque each way. Most go down real easy.
    Nov 2004
    3028
    A BPT series 2 standard already has the air cylinder. The old Series 2 NC has the air cylinder and a knee ball screw and drive. Plus X and Y ball screws and drives. This was mentioned in a prior post. It would save a lot of time and work for you.
    George
    Jul 2005
    5
    I purchased a series 2 nc a few months ago and am having trouble. Serial number t625 what year? I have power at the control (Boss ?) Tape reader missing. There is an rs232 port attatched and the mill came with a pc and the quick step program which he never set up or used. Previous owner said he had the axis moving but not the spindle. I cannot get anything to work.The fans in the control tower and in the box on the mahine work . He said the display worked and he used the controls to move the axis. All I have is the light on the limit overide on (red) and no led in the display. I can get the spindle to go clockwise and counterclockwise by pressing the relay in the box on the back of the machine. Could I have the wires from the control tower hooked up wrong? They were labeled but some are redndant and I dont know if it matters which one they go on. For instance there are two x5. Any help would be gratefully appreciated. 4 hp with spindle wizard. Do I also need the air on the z to be on, would that make a difference? I would rather get it going than do a conversion now especially since I dont know how much wear is on the machine. From the sound of the spindle growling I think the head needs some work. A\t certain points the speed control on head is stiff. Would this indicate worn pulley shafts?
    Nov 2004
    3028
    Oh Boy!
    Mark,
    When I was with BPT, I did work a lot on these but even back then, they were almost Jurrasic. The last one I worked on was about 10 years ago as everything is so old in them, the connections are corroded, and there are no parts for these (a lot of the ICs have not been made for 20 years), that it is not cost effective to try and get one running. At least when hiring a service engineer to do it for you.
    The NC2 was designed to run constantly off a tape reader. That is what NC means. A CNC can download a program into memory, by RS232 or a tapereader, and run from there.
    For each part a NC makes, the tape will go through the tape reader once, a little bit at a time. A long time ago, these REMEX tape readers were getting troublesome, so some people converted to tape emulators. I did see one. That is perhaps what is attached to yours. I do not have any knowledge of these. Typically the company making them had all the technical expertice and supported them.
    Later knowing the NC2 limitation, BPT came out with the NC2A which could accept the C5 or C6 option. This was the BOSS 5 or 6 control in a small desk and converted the NC to a CNC.
    To keep an NC2 running was a chore. It had the problems or the newer BOSS machines with stepping motors, transistors that blew, but also it had that pile of HNL cards in the back of the machine and the SCR boards.
    The HNL (hi noise immune logic cards) are what run the spindle wizard and do a lot of the M functions.
    The SCR boards (3 or 4 of them) turn on the spindle and flood and/or mist, etc.
    Do you have a maintenance manual? You will need one for all the schematics.
    Maybe http://www.machinemanuals.net/ has one.
    You may need an operating manual as well. I do not remember even how to enable the drives. On a BOSS machine there is a limit over-ride button that is pressed, the limit light shuts off, and the drives are on, unless you are on a limit switch. In that case press and hold the button and jog off the limit.
    It sounds like your limit string may be open, your 24VDC power may not be there, etc.
    Each motor has 5 wires. IE: X1, X2, X3, X4 and X5, X5. The two 5 wires are interchangable or they would not have the same designation.
    Maybe the knee is all the way down, and that is why your limit string is open. Air is necessary for the knee. Set to 40 PSI with an empty table. For every 100 pounds of additional weight on the table, go up 5 PSI. Otherwise the Z stepper will not lift the table. Too much pressure andthe Z stepper will not lower the table. (service call I had)
    If I ever find the personwho designed the Spindle Wizard, I will choke him to death with my bare hands. I will have to stand in line as every other person who has spent weeks of their lives trying to get them to work right will be there also. There are little switches and solenoids everywhere. You will need the operating manual to understand this. This is also why it would be so difficult to write a PLCprogram for this machine keeping the spindle wizard and all of its I/Os.
    I am curious why you mention LEDs. The NC2 tower had bulbs in it. When designed, LEDs were found only on UFOs. The C5 or C6 did have a segmented LED display. If they are not lit, there is a power supply issue or something is not hooked up.
    Well, I am late for work....
    This may get you a LITTLE closer to a functioning machine.
    George
    Jun 2005
    46
    How about scraping the complete original control, keep the rear cabinet, and retrofit it? This is a perfect machine to start with, sturdy with ball screws and box ways with a lube system.
    I would replace the steppers if you can afford to. Go with a min of 1600oz-in. Nema42 with 5/8 shaft bolt up really nice.
    There are many threads about the BridgePort retrofit.
    Dec 2004
    293
    Quote Originally Posted by muleworks
    Hey JD,
    Chris
    Little late on the reply, sorry.
    <IMHO> The bigger the iron the better. I still would like a little more beef at times. Also the table is bigger so you can set up more parts for a run if you wanted to. Finally, and perhaps the most important, the Series II appear to be designed for the CNC to a greater extent. Maybe that's just my mis-understanding. Maybe the size difference just accomodates the CNC mechanicals better than the Series I. The Series I is really pretty compact in my opinion, give what it does.
    In either case having the Y axis drive in the head is going to be better than bolting a conversion on the front like I am doing.
    Nov 2004
    3028
    Y motor is on the knee. Z motor is also on the knee.
    You will need to keep the 110 VAC circuits to run the spindle contactors, etc. as well as the 220 VAC the spindle.
    George
    Jun 2005
    46
    You could also use a VFD and eliminate the 3 phase requirements for your machine. Using a VFD you can control it with the software and/or via manual switches.
    At least my machine has a 3 phase splindle motor. The VFD made it really nice.
    Dec 2004
    293
    Oh....it's on the knee! I never knew that! Cool. Ok that makes a lot more sense to me now. That's even better since that gives you a lot more travel in the Z axis.
    Thanks George!
  1. Manual lathe CNC conversion
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 08-20-2005, 09:56 PM
  2. Pics of my RF45 clone cnc conversion with flood coolant
    By CNCPlastic in forum Knee Vertical Mills
    Last Post: 01-26-2005, 09:02 PM
  3. Gorton P1-2 + Sherline CNC mill conversion.
    By jaydee116 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-12-2004, 06:10 AM
  4. First Impressions for CNC mini mill conversion
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2004, 03:37 AM
  5. possible cnc conversion on homier mini mill
    By WsW-WYATT in forum Benchtop Machines
    Last Post: 03-27-2004, 02:24 PM
