586,912 active members*
3,457 visitors online*
    56
    15MM vs. 20MM RAILS
    Hi all, I am building a new cnc router with a table cutting size of 42" x 30".
    I am planning on using 80/20 extrusion, and I am going to use some linear rails, either Hiwin or THK. Do any of you see a performance difference between 15mm rails and 20mm rails? just for clarification, the rail widths are 15mm and 20mm, the heights are the same on both at 15mm.
    Mar 2007
    51
    What kind of rail? this is more important than size.
    Four point HSR can hold load in all direction, SR not.
    A bigger rail can hold higher load, wider rail can hold higher load in some direction, check manufacturer specs they are quite detailled about this.
    15362
    woodworker2
    For long rails you want them at least 20mm/25mm wide, as the 15mm are harder to get straight in long lengths,unless you have a machined surface with a shoulder to put them on
    Mounting on extrusion does not give the 15mm rail much support,3.5mm each side of the slot is not enough
    Mactec54
    56
    Thank you, I have looked at Hiwin and THK, and I can't give you the model numbers, but I did make sure that in the descriptions, that they could be mounted in a vertical application.
  1. 15mm ally plate
    By stk2008 in forum DIY CNC Router Table Machines
    Last Post: 10-27-2009, 06:42 PM
  2. 16mm vs. 20mm supported linear rails...
    By WilliamD in forum DIY CNC Router Table Machines
    Last Post: 12-20-2008, 12:37 AM
  3. Replies: 12
    Last Post: 10-07-2008, 12:08 PM
  4. Why do some people say you need 20mm rails???
    By Mr.Nerd in forum DIY CNC Router Table Machines
    Last Post: 06-29-2006, 01:05 AM
