586,060 active members*
4,153 visitors online*
    Sep 2010
    Question Fusion 640M won't see .EIA prgs in directories.
    One of our Fusion 640M controls will no longer show .EIA prgs through the control software. If I look at the directory with windows explorer the file appears normally. This function used to work. I'm guessing tha a parameter or setting got changed accidently. Any help is appreciated.
    Feb 2007
    198
    it might be a windows thing where you think your file name is 1234.eia, but if you "hide extentions for known file types", a setting in windows explorer, I think?, your computer may actually be seeing 1234.eia.txt.
    I think if you select a file in windows explorer and right click "properties", then teh real full file name is shown.
    and for Data I/O from a floppy or jump drive, the programs must be exactly one sub-directory deep.
    jim
  1. 1999 Mazak FJV-250 with Fusion 640M Control
    By Hastx in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-11-2010, 04:42 PM
  2. lost programs on fusion 640m
    By Jsheldon in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-13-2010, 03:57 PM
  3. Using DPRNT on Fusion 640M Control
    By marcwdci in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-12-2008, 04:21 PM
  4. Post processor for Fusion 640M
    By naytep in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-03-2007, 01:30 PM
  5. fusion 640m rs232 comm
    By camcutter in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-30-2007, 05:23 PM
