We have the formulas to get output from a fresnel integral....we can even get that data on a spread sheet.
How to write a program to take the data..better yet the formula inputs and turn it into G-Code
will you be making the lens on a lathe or on a mill?
what material?
does your output geometry look something like this?
http://en.wikipedia.org/wiki/File:Fresnel_lens.svg
I recall producing an Application for a UK client, a good few years back, which
did exactly this.
Basically the method was :-
CAD Module
Using VB script a macro was produced which produced the Curve based
the equation and some other Parameters such as Included Angle+radius.
The VB script would then calculate a series of points which lie on the
curve.
The VB script would then submit these points to the CAD Curve Fitting
routine which would produce a Tangential (Convex or Concave) curve
which then be passed to the CAM Turning module.
CAM Turning Module
The CAM turning module would then be used to produce a toolpath.
This was a few years ago and since then the CAD module has aquired a Template system which could be employed and the CAD + CAM modules are available as Servers using microsoft auto technology.
These new features make it possible to develope a fully automated Bespoke
application which take the initial parameters and produce a dimensioned
drawing and G code file witht he Dolphin modules being used as background servers invisible to the user.
michael
Dolphin CAD CAM systems Ltd
Dolphin CAD CAM Ltd
if you can make the calculations in a xls spreadsheet, then you can also recreate these formula's in macro B (i can only speak about fanuc cnc's), no special software requiered.
the calculation will save the point data in a sequential variable range, start & end number decided by you.
then write a normal cnc part program that will call this variable-range in sequence to produce the shape calculated.
the variable range is called by using a loop that index the variable number, making the program very short.
Post the drawing and formulae for specific suggestions.
