586,677 active members*
3,091 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > IDC B8001 servodrive manual request
Page 1 of 2 12
Results 1 to 20 of 23
    Feb 2007
    11
    I have a machine that uses IDC B8001 servodrives. Manual of the drives seems to be lost. Does anybody have a pdf copy of this manual? I have looked at te Kollmorgen website but it's not there; only the "B8961 and B8962 manual" is available.
    Thank you very much.
    Jun 2009
    35
    Post
    Here's a copy. I used to work for Kollmorgen, I have lots of their documentation and a lot of their obsolete components in stock where I currently work, especially BDS4, BDS5 and Servostar CD drives.
    Matt
    Attached Files Attached Files
    Matt Adams - Motion Control Application Engineer
    IMAC Motion Control - Elgin, IL
    Feb 2007
    11
    Thank you very much for your answer.
    It seems that my drive had a tracking error. I had to replace a faulty drive (doesn't power on anymore). Perhaps that the configuration file I have downloaded in the new drive hasn't the good parameters. I'll check it.
    The two machines must still last one year before retrofit. I hope that I will have no more problems, because all spare drives I have are defect.
    Sep 2010
    1765
    Hi Matt. Beat me to the punch sending this Hope all is good with you.
    Jan 2012
    Hi all,
    I have a fault IDC B8001 servodrive. I want to get the configuration file from the fault one to download into the spare one. Please introduce me the software or send me the link to download this software. Tks.
    Sep 2010
    1765
    I have the software; there is no link anymore as this product is long obsolete. Post an email address that i can send software to that will accept exe files & size to 12mb and I will email to you.
    Jan 2012
    Hi Mike,
    My mail is [email protected] or [email protected]. Thank you so much.
    Sep 2010
    1765
    emailed to both addresses two emails: one 12mb, other 3mb. not sure which of the 2 programs u want. let us know if they come thru ok. both zip files
    Feb 2015
    4
    Quote Originally Posted by mike_Kilroy View Post
    Any chance you can also send me a copy of the program? el_gotico at me.com. Thanks
    Sep 2010
    1765
    Re: IDC B8001 servodrive manual request
    Quote Originally Posted by el_gotico View Post
    sure, but I have no clue what you want. Hell, I can't remember stuff from 1 month ago, let alone 3 years ago! If u tell me WHAT you want, and I can provide it, I will.
    Feb 2015
    4
    I'm looking for the configuration program for the B8001 controller. Thanks for your help
    Feb 2015
    4
    Same 2 you sent to hoteltango so I may see which one works for me. I'm in the same situation he had. Thanks
    Jan 2012
    Hi Mike,
    I've received them, I will try connecting to upload the configuration file.
    Thank you very much
    Aug 2015
    6
    I downloaded ServorTuner software from Kollmorgen web site. It ask for a password to download motor parameters to drive.Does anybody know the password?
    Password is not for the drive it is for the software.
    Aug 2015
    6
    Message box says "The configuration file load has been cancelled due to write protection. locate or reset the PIN number for this drive."
    so it could be PIN for drive itself, my original drive does not have a PIN, this came up only with the spare drive.
    Aug 2015
    6
    Just to give some background, Original drive was configured using ServoTuner V 3.3. This software version did not communicate with spare drive. SO I downloaded latest version from Kollmorgen which is Version 3.5.8. This version ask for PIN to overwrite drive configuration. I am not sure where to get the PIN. Spare drive is brand new. Not configured to any motor before.
    Sep 2010
    1765
    Not sure exactly what your issue is, but here is info from one of the app engineers in response to my asking your question, as a distributor of this stuff, for you:
    The ServoTuner software has a user established password. To get around that password, search for a file called "quickset.ini". Open it as a text file in Notepad. The value of line item "ppItem25" is the password. You can read it and use it, or you can change it and use the new one. I think you can delete it (the value, not the entire line item), and then there will be no password required.
    Aug 2015
    6
    Thanks Mike! I was able to download config files after changing password!
    Thanks for the quick help!
    Aug 2015
    6
    I have new drives that when I tried to use both of them gives same error 6 (Encorder counter over speed) when I tried to go above 3000rpm.
    No error below 3000rmp.
    I've changed motor/encorder but problem remains.
    If I change the drive with an older version from a running tool no issue found. Problem follows the drive.
    Problem drive firmware version is TEK(32DA41 V2.08 9D24(3)
    Older drives with firmware TEK(32DA41 V2.04 432D(3) works fine without issue.
    Any idea how to downgrade firmware to older version?
    - - - Updated - - -
    I need to run the motor at 4800rpm
    Aug 2015
    6
    I tried that and it still didn't work. I had the *.mtr file from the old drive and uploaded it to the new drive and still no luck.
    Finally I struggled for a week together with the application engineer from Kollmorgen application engineer to configure their latest AKD drive and yesterday finally succeeded!!
    Kind of embarrassing for such a simple application with only analog control voltage and drive enable signal used to run a brushless motor at 4800rpm,
    we had to use drive with 1337 page user guide and a 212 page installation manual!!!
    Although marketing flyers advertise "One button tuning" and simple configuration in practice its always a different story!!
    Thanks Mike for your reply.
Page 1 of 2 12
  1. Manual request Fanuc A20B-0004-017
    By markder13 in forum Uncategorised MetalWorking Machines
    Last Post: 12-27-2013, 02:20 PM
  2. Replies: 3
    Last Post: 05-22-2013, 05:59 PM
  3. Milltronics Centurion 1 manual request.
    By i_fab2 in forum Machinery Manuals / Brochures
    Last Post: 04-13-2013, 02:37 AM
  4. Request for Manual for CM120 laser cutter/engraver
    By surfsen in forum Machinery Manuals / Brochures
    Last Post: 10-01-2011, 08:10 AM
  5. manual request
    By MysticMonkey in forum Okuma
    Last Post: 11-25-2009, 10:57 AM
