586,106 active members*
3,062 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > Bending Stainless #8 (mirror finish)
    Oct 2006
    24
    What's the best way to bend #8 Stainless Steel without marring the mirrored surface. Would be sheet of approx 0.8mm...if I can do it...
    Thanks for any tips
    Jul 2005
    12177
    I expect the best way would be to use a press brake with a polyurethane bottom die and have the mirror finish side against the bottom die.
    Oct 2006
    24
    Thanks Geof -didn't even know they could get PU up to that hardness level -learn something new every day!
    Sep 2009
    313
    If you can't do it yourself let us know, we do sheet metal fabrication, good prices.
  1. Mirror finish steel and aluminum parts vibratory bowl?
    By Toggle in forum Material Machining Solutions
    Last Post: 10-18-2018, 10:14 AM
  2. I want that mirror finish
    By CORBIN92087 in forum MetalWork Discussion
    Last Post: 09-12-2009, 05:11 PM
  3. Mirror finish on Aluminum?
    By RP Designs in forum MetalWork Discussion
    Last Post: 09-11-2009, 11:05 PM
  4. Bending Stainless Steel Bars
    By Keith Weston in forum Bending, Forging, Extrusion...
    Last Post: 02-14-2009, 01:46 PM
  5. Bending stainless steel tubing
    By eljainc in forum Bending, Forging, Extrusion...
    Last Post: 12-27-2007, 08:08 AM
