GenSwiss has introduced the GenBore® ID Triple Tool Holder that adds three ID tool stations in place of a standard OD turning position on most Swiss-Type CNC machines. With The GenBore Tool Holder ID work can be expanded to include spotting, boring or drilling, all from one position
for more cost-effective machining of complex parts. In addition, the tool holder features easy integration of high pressure coolant delivery systems, and can be configured for thru-coolant delivery through one, two or all three tool positions. The GenBore includes (3) ER11 5/8” shank collet sleeves, removable location screw to re-position the holder on the gang plate, and set screws on both sides
of the holder to suit RH & LH machine layouts. The ½” shank includes shim-plate for machines using 5/8” shank tooling. When requiredThe GenBore can be easily removed returning to a standard OD turning position to suit specific machining requirements.
For more information: http://www.genswiss.com/genbore_swisstool.htm
