586,533 active members*
2,934 visitors online*
    Nov 2007
    2466
    vacuum plenum
    i am gonna make a new plenum fot the router, last one was 1.5" squares .5 wide and .375 deep in four zones.
    are smaller channels better, is there a formula, we use high cfm blower
    are there advantages between aluminum and phenolic (grade) as the last one i made from mdf and sealed well.
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    107
    This may be too late for you but I made a phenolic top for my Precix using a 1 inch square with .250 channels. I also used the Besse and Neimi design using steel plugs in 240 vacuum holes to zone my table. Worked well. However, I later changed that top with a 1 inch cast aluminum top with 30mm (I think) squares. This allowed me to use Better Vacuumpods on it. I have since dis mantled this Precix and kept the vacuum top for a custom build. I can tell you that aluminum is expensive, hard to machine but definitely worth it. That being said, I am now semi retired but bought a used Flexicam 5x12 for my retirement. It has a 25mm phenolic table with 6 zones. The channels are 9mm (.360) and .375 round gasket from AllStar works great. I feel the larger channel gives me better flow throughout the spoilboard. One day my house in California will sell and I will use the existing phenolic table as a plenum and top it with 1 inch of aluminum. I will then use the Bessie / Neimi style square designed to use my own pod made from delrin.
    Nov 2007
    2466
    thanks, no not to late, i have been busy (good in this economy) and will be reworking the table after the new year!
    i plan to use 3/4 aluminum with a machined grid
  1. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  2. vaccum Plenum table chamber
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 09-24-2010, 04:17 PM
  3. 1" PVC for vacuum plenum
    By ddgman2001 in forum DIY CNC Router Table Machines
    Last Post: 07-18-2009, 09:23 PM
  4. How much vacuum?
    By nbuchholz in forum Open Source CNC Machine Designs
    Last Post: 05-25-2006, 10:46 PM
  5. Cast aluminum Runners and Plenum
    By Kmed in forum Employment Opportunity
    Last Post: 08-31-2005, 05:35 AM
