586,121 active members*
3,303 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Inverse time- 5 axis Acramatic 950
Results 1 to 9 of 9
    Sep 2010
    Good morning all
    Would you happen to have any good sample code that you can post in this thread showing the proper format for inverse time (G93) on a Cincinnati 5 axis profiler, circa 1998?
    Thanks for any help
    Feb 2007
    664
    Sep 2010
    thanks for the reply. I am aware of how inverse time works, it is just that I don't have any actual, working sample code for this particular controller to look at.
    Aug 2008
    386
    Looks simple enought to me.
    For my CT controller
    G90G1G93X5F5
    would command a move to absolute x5 that takes 5 minutes.
    Joe
    Sep 2010
    inverse time
    hi Joe
    thanks for the response, but I was looking for actual 5 AXIS sample code. No one would use inverse feed to make a simple 2 axis linear move.
    Is there anyone on this forum that happens to have experience with 5 axis programming on the Acramatic 950 control using inverse feed?
    thank you
    Feb 2010
    71
    Inverse time feed
    Best I can come up with is a 4 axis inverse time feed program for my Acramatic 900.
    I hope it is of some help.
    Doug
    Attached Files Attached Files
    Apr 2006
    130
    Inverse Time on Acramatic 9500
    Good question.
    I have a similar question but can't put my finger on an Acramatic manual.
    My question is whether the FRN (feed rate number) is issued as 1/min or 1/sec. I believe the rest of the format is pretty much standard inverse time.
    Feb 2010
    71
    Inverse time feed
    My feed rate is 1/min. I do believe there is an error inthe code I posted, it would seem to be missing at least 1 digit in the FRN. I'll have to take a look at it again.
    Doug
    Feb 2010
    71
    Inverse time feed
    Alan,
    I had to go back and fix my post processor for inverse time feed. While I was at it I did a little research to see if I could come up with an easier way to explain inverse time feed. Here goes.
    The feed rate number (FRN) is the denominator of a fraction (1/FRN). This fraction gives you the actual time to cover the distance of the cut in seconds.
    To calculate FRN you need: Desired feed rate in inches per minute(V) and distance of the cut in inches(Dist).
    The formula:
    FRN = V/(60*Dist)
    Three axis example:
    You need to cut a line between X0 Y0 and X4 Y3 @ 10.0 IPM (V)
    To caculate the distance I will use the formula:
    a^2 + b^2 = c^2.
    I will use "a" to represent the "X" value = 4
    I will use "b" to represent the "Y" value = 3
    I will use "c" to represent the "Dist" value
    4^2 +3^2 = c^2
    16 + 9 = c^2
    25 = c^2
    5 = c
    Dist = 5
    FRN calculation:
    FRN = V/(60*Dist)
    FRN = 10/(60*5)
    FRN = 10/300
    FRN = .033
    Inverse time number would then be : 1/.033 (1/FRN)
    Actual cut time would be: 1/.033 = 30.303 seconds
    To double check this just divide: 5/10 ("Dist" by "V") = .5 minutes
    A very simple example but it gets to the point.
    The only diffrence with 4th and 5th axis is how you calculate "Dist"
    I hope this is of use to somebody
    Doug
  1. G93 Inverse time
    By DaveMCINC in forum Fanuc
    Last Post: 12-07-2009, 06:22 PM
  2. acramatic 2100,reseting time-date
    By lineborn in forum Cincinnati CNC
    Last Post: 06-12-2009, 04:41 PM
  3. Inverse Time feedrate for 4th Axis
    By slideleft in forum Haas Mills
    Last Post: 12-09-2008, 04:39 AM
  4. G93 Inverse Time Feed Mode
    By MarkT in forum Haas Mills
    Last Post: 01-18-2007, 07:28 PM
  5. Inverse time feeds with a 4th axis
    By nervis1 in forum Fadal
    Last Post: 11-06-2004, 06:43 AM
