I'm wondering if anyone used these motors off ebay? A 3/8 shaft worries me, seems a little puny...
I'm retrofitting a bport
Reliance Electric DC Servo motor
NEMA 34 Frame
Model 0690
Back EMF Constant, ke = 62 V/kRPM
Torque Constant, kt = 5.5 lb-In/Amp
At just 10 amps, that's 55 Lb-In = 880 Oz-In.
Nominal Speed Rating: 1750 RPM
Nominal Voltage Rating: 120 Volts
Continuous Current Rating: 4 Amps
Peak Current: 20 Amps
Continuous Power Rating: 1/2 H.P.
Motor Body Diameter: 3.38"
Motor Body Length: 9.0"
Shaft Diameter: 0.375" x 1.13" Long
Integral Encoder: Agilent P/N HEDS 5605#A06
500 Line yielding 2000 Counts/Rev.
Encoder is mounted under protective steel cover on tail end of motor.
Also says:
*** THESE WORK WELL WITH GECKO DRIVES.
The lower voltage rating of the Gecko is not a problem:
With an 80 volt supply, you can expect
~1750 RPM
~1100 Oz-In peak Torque
Thanks !
