586,119 active members*
3,449 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > Need help to modfy the MPLFAN.PST in Mastercam 9.1
Results 1 to 8 of 8
    May 2004
    61
    Exclamation Need help to modfy the MPLFAN.PST in Mastercam 9.1
    HI postprocessor Gurus
    I need help as stated above. There are a couple of things i need to change to work with my controller(Mach3).
    #1. Tool change and tool offset output. Current output is T0101
    as in Tool 1 Offset 1
    Output needs to be: T1 being the tool number
    G43 H1 being the tool offset
    Same go's for ending to cancel: T1
    G49 H1 Canceling the offset
    #2. G32 command Current output G32 Xxx Yyy Eee
    E being the pitch of the thread.
    Output needs to be: G32 Xxx Yyy Fff
    F being the pitch as feed per rev.
    #3. G76 command
    Output needs to be:
    G76 Xxx Zzz Jjj Kkk Qqq Ppp Hhh Iii Lll Ccc Bbb Ttt
    Where X=EndX Mandatory
    Z=EndZ Mandatory
    J=StartX
    K=StartZ
    Q= spring passes
    P=Pitch or lead of thread
    H=# of passes for thread
    I= infeed Angle
    L=Chamfer
    C=Clearance
    B=Depth of last pass
    T=Taper
    Any help will be apreciated.I would prefer directions on how to change the post rather than one that has been changed.It is the only way to learn when you do it your self.
    Deon Gerber
    (South Africa)
    May 2004
    61
    RE: Post help update
    Hi
    O OH!! . Looks like the guys on the forum is stuck in helping with my problem.
    Not to worry. I some how expected this to happen. In my search for awnsers I got hold of the Post procesor Ref. Guide from Mastercam. It took a while to figure out but I managed to fix som of my problems.Here they are!!!
    #1. Tool change almost fixed. Everything outputs fine exept for the offset number value( H ). It stays on 0.It does not change from tool to tool. Still working on this one!!!
    #2. G32 comand fixed :banana:
    #3. G76 still in the pipe line. Any help will be apreciated!!!!!!
    Deon
    South Africa
    Feb 2005
    6
    ref guide
    I am just trying to modify our post for a Fagor 8055. Where did you get hole of the ref guide you mentioned
    Sep 2004
    145
    Hi guys,
    MBFisher, the post reference should be available from your MasterCam dealer. I can help you modify your post if you want. Don't know anything about a Fagor though.
    Deon, send me your post, I'll look at it and see if I can fix it. I'm finishing up my conversion of a Seig mini lathe that I'll be using Mach 3 on so we can work together
    Insanity "doing the same thing and expecting a different result"
    Mark
    www.mcoates.com
    Feb 2005
    6
    that would be great if you could give me a hand Mark C. I have managed to fumble my way through modifying some of it to get what I want but am stuck on a coulpe of things. how can I send you a copy with some details of what I am stuck on.
    Cheers
    mark fisher
    Sep 2004
    145
    Email me a copy at [email protected] and also a copy of the G code the way its posted and what you want. I'll try to get to it in a couple of days. Oh yeah what version of mastercam?
    Mark
    www.mcoates.com
    Feb 2005
    6
    whoops , just sent it to you at your private email address, hope that is ok
    Sep 2005
    92
    You can find the post for Mastercam here
    http://www.emastercam.com/posts/edu_x.html
  1. mastercam 9.1 help
    By Mechanical d in forum Mastercam
    Last Post: 11-22-2005, 03:56 AM
  2. Mastercam 9.1 and Win XP
    By deon in forum Mastercam
    Last Post: 04-27-2005, 03:55 AM
  3. Mastercam Jingle Bells
    By Rekd in forum Mastercam
    Last Post: 01-02-2005, 08:20 PM
  4. Mastercam 9.1 to Mach2 post
    By deon in forum Post Processors for MC
    Last Post: 10-13-2004, 05:39 AM
