I need quantity 1 of the following attachment.
This is a slightly modified version of the Ron Steel CNC Mini lathe part, and is used to connect the leadscrew to the cross slide assembly.
The center hole is .625 (there was a conflict on the drawing, the dim is right)
Material should be Mild steel 1018 or similar.
Include lead time, cost & shipping estimate to 40014 (Louisville KY area)
Thank you
