586,341 active members*
3,365 visitors online*
Results 1 to 20 of 20
    May 2005
    45
    dro in manual mode...
    I searched but couldn't find...
    Will the d.r.o. work in mach 2 while in manual mode, or is there even a manual mode?
    Apr 2003
    1079
    Sure, there is a jog mode where you can set the jog speed, so set real slow for manual cutting, or there is an MDI mode where you can input lines of code one at a time. The DRO's will work with either mode.
    May 2005
    45
    Question thanks..
    kong,
    Sorry, I wasn't clear,
    will the dro work if you manually crank the handles with the servo's off?
    Thanks...
    Apr 2003
    1079
    Ah, in that case it won't work.
    I know there is provision for encoder inputs directly into Mach2, but this is too advanced for me. There may be someone that has used these inputs though?
    May 2005
    45
    Anybody....
    May 2005
    45
    Talking ?
    Throw me a bone...
    Quote Originally Posted by triberman
    kong,
    Thanks...
    If you want to use the encoders for the servos, then no. I think that you can, however, use an additional encoder, (possibly mounted to the other end of the screw?) to use DRO's when manually using your machine. Make sense?
    May 2005
    45
    Cool I Think So..
    Thanks..
    But the mach2 software wouldn't show position without the servo's powered? It sounds like if I need a dro for running manually I'm outta 700.00 for a sargon.
    BTW: Sargon's are the most reasonably priced dro's I've bought for my shop and they hold up well if installed properly.
    (if anybody is shopping for one)
    Mach2 has many different types of DRO's . The main DRO's display the commanded position, NOT the position the encoder provides. The reason is that the servo encoders are connected to the drives (gecko or Rutex usually), which is where the loop is closed. Mach2 never sees that encoder info. That's why I said you'd need to add another encoder to each axis, which could then provide info to another set of DRO's in Mach2. This encoder would be independant from the servo drives, so it would work if the drives weren't powered up.
    Aug 2004
    2849
    triberman,
    If you have a CNC setup...why do you want to run in manual mode? My personal belief is that if you go down the CNC route you shouldn't go back to manual.
    May 2005
    45
    personal preference...
    Ahhh, I get it. That should be easy if I can figure out how to hook them up. That can wait until after I'm up and going... Thanks
    VTX:
    Everyone is different, but what I've discovered in my 17 years machining is that someone who knows when to do an operation manually is way more productive. Before even the fastest programmer can make chips on some setups, often it could have been done manually already. And jogging gives you no "feel". I'm only talking about certain operations on ez-trak or accu-rite type machines.
    This is why virtually every knee mill retro-fit has fold-away handles, quick release quill drives, and dro's in manual mode. Elrod has even gone as far as to have a quill stop for manual mode in front of the quill drive.
    It's my job to notice these things.
    What works for some may not work for others, and there are alot of different types of applications for a cnc mill.
    But, you know what they say about opinions....and mine's no different!
    Aug 2004
    2849
    triberman...I think you're right if you're doing one-ofs and don't need any traceability of what dimensions were actually used....
    430
    Manual machining is an art unto itself. Many aspects of manual machining are incorporated into our CNC work, but not all of the nuances. I work in a glassblowing shop now where most things are still done manually, (I am working on some automation solutions). It is always nice to see a master craftsman's hands at work.
    Keeping our eyes open to potential solutions is a good idea, even if (God forbid!) it does mean doing something manually.
    Colin
    There is a new product (encoder board) coming out soon for Mach2 which will do exactly what you're looking for. Here is some info from the Yahoo group.
    Jim Cullins and I (mostly him) have developed and tested an interface that does
    this and makes Mach a true closed loop software. It is ready for release and we
    are just waiting on production boards. When it is released I will post a link to
    where they are available. It works great, I'm using it on my mills now. It
    monitors axis position and halts machine on a discrepancy and triggers a
    sonalert. The board provides 4 more outputs and up to 8 additional inputs for
    probes, triggers, MPG's, etc. Also, it has the ability to collect encoder data
    when mach is in "reset" and display it on the screen. In other words, put Mach
    in reset and crank the handles and the machine position is displayed in DRO's
    for manual machining providing an E-stop circuit is used that shuts down the
    motors power supply. So, no more ruined parts.
    Stay tuned as we will be announcing it very soon.
    May 2005
    45
    awesome!
    Thanks for the info, should save some bucks...
    Dec 2004
    524
    VTX:
    My Elrod does NOT have a quill stop. But you can disengage the quill feed.
    Using EMC with univpwm cards, turning the X and Y axis handwheels tracks the position in the DRO.
    KL
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    May 2005
    45
    Thanks Ken
    The "smart stop" is an option with elrod's quill drive. I don't know how long it's been available.
    Jul 2005
    46
    Given the cost of manual DROs this sounds like an excellent solution.
    I am by far no expert in this field, but a questions arises. What would be the implication with the ballscrews? Without the motors holding them, will they not have the tendency to move?
    Either way it is not an option for me. Along with steppers, I have no manual controls on my machine.
    Would be cool if it does work though.
    Chris
    Quote Originally Posted by chrispy
    You can't use ballscrews on a manual machine, because yes, they'll move.
    May 2005
    45
    Have to use the table locks.
  1. Simple cheap CNC router
    By mwalach in forum DIY CNC Router Table Machines
    Last Post: 10-29-2005, 01:08 AM
  2. Extremely basic machining question.
    By touser in forum MetalWork Discussion
    Last Post: 06-19-2005, 06:51 AM
  3. Simple question?
    By johnney0005 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-26-2005, 05:52 PM
  4. simple newbie question
    By swarfmacdaddy in forum G-Code Programing
    Last Post: 01-31-2005, 01:37 AM
  5. Just a question about plunge milling.
    By Machine1 in forum Hard / High Speed Machining
    Last Post: 01-29-2004, 03:36 AM
