586,296 active members*
4,037 visitors online*
    Sep 2010
    Exclamation hedrolic problem in maho 600e
    hello
    I'm in Algeria sarl mecanin I have a machine Maho MH 600 E / 432 CNC, that you have already repaired in France are serial number is: 636073. Yesterday I had the following problem:
    * The machine was stopped during machining, the error affuchon * O5 (interrupt message backup).
    * I set the machine off and then I reset the machine. I cleared the toolholder head and I said the machining cycle, after some minutes it did the same thing, switch the pump lubrication jumps
    The machine stops and displays the same error * O5 /
    * Now if I may start the machine, I press the button "WATER MARKET", I continued down and erase the error signals indicated by pressing the CLEAR button.
    dice that I remove her hand, she displays the same error * O5.
    * Note: if I continued pressing "HYDRAULIC POWER" button and I press "CLEAR" and at the same time someone exit the circuit breaker for pump lubrication and maintenance down the error appeared no more
    because when pressing "HUDRAU & CLEAR" unable to run the circuit breaker.
    * After checking an electric circuit, our technician we adit as map No. 8 (enter card out 24V) is not out to drive the 24V relay that feeds the coil circuit.
    That Wed cough I know about this outage.
    * What can you advise me. If the card is No. 8 must be changed, is I will have little
    We await your advice please accept my sincere greetings.
    Sep 2010
    same problem?
    Yami,
    Did you solve your problem? I might have a similiar on a MH800 and I am interested if you have a solution.
  1. Drip feed with MAHO 600E-Phillips cnc432
    By Grusse in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-20-2010, 09:52 AM
  2. Change Battery on Maho 600E, Phillips 432
    By Konrad in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 08-16-2010, 04:28 AM
  3. MAHO-PHILIPS 432 M60 and G23 problem
    By micktat in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-03-2009, 11:10 PM
  4. Maho 800E Toolmagazine problem
    By kotten1 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 02-20-2009, 10:13 PM
  5. Maho 400E or 600E
    By HKgunslinger in forum Want To Buy...Need help!
    Last Post: 11-10-2008, 02:12 AM
