586,113 active members*
3,040 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > MeshCAM 4 Build, 2 sided machining
Results 1 to 6 of 6
    Aug 2004
    2849
    Has anyone else run into this problem?
    When I load the bottom side, the geometry is about 2 inches south of the y-axis. I'm using SW as the zero.
    It appears to be nested below where the top geometry would normally appear.
    The same file in Build 7283 looks fine.
    Paul
    Aug 2004
    2849
    So, I haven't had any response to my question.
    Is the problem not clearly stated or is someone working on this?
    Paul
    What build # are you using? It looks like there was possibly a fix for this in build 21.
    I went back to 18, and it looks a bit strange, but 22 looks fine.
    Aug 2004
    2849
    Thanks, I'm using build 17.
    I'll look for the latest build.
    Paul
    In MeshCAM, go to Help>Check for updates.
    Apr 2003
    178
    In V4 I added the hidden option for the zero to be locked on a particular corner of the stock instead of locking it to a point relative to the machine table as it has been done in MeshCAM for years. Unfortunately, I made it default to the new version instead of the old version. V22 fixed this and put it back.
    FWIW, the new option would make the whole process less dependent on the exact stock dimensions entered in MeshCAM at the expense of a more difficult setup on the mill.
    -Robert
  1. 2-sided Machining - Centering the Part and Zeroing
    By ViperTX in forum Uncategorised CAM Discussion
    Last Post: 12-22-2011, 07:10 PM
  2. 2 Sided Machining and outline of part
    Last Post: 06-12-2010, 05:50 AM
  3. Multi-sided machining with VM5 Pro
    By rzmac in forum Visual Mill
    Last Post: 03-12-2010, 06:03 AM
  4. Unable to place support tags on 2-sided machining
    By LongRat in forum Uncategorised CAM Discussion
    Last Post: 07-22-2008, 08:01 PM
  5. Can MeshCAM do 4 or more sided milling?
    By digits in forum Uncategorised CAM Discussion
    Last Post: 04-03-2008, 11:14 PM
