Originally Posted by
mactec54
cruzin
The first thing you will have to do is get some shielded cable for the job, or your house
TV Etc will go nuts, IGUS for your cable
Yes the 3 motor wires will go to U/T1 V/T2 W/T3, but you need to use shielded cable for this, & ground the shield at the Drive end only,This cable will have 3 Black 1 Green & a shield
Your input power I guess is 220 single phase as you have not said, this you want to use a shielded cable as well, this Cable/ wire will have 2 Black 1 Green & a shield( it can be the same cable as above you just cut one of the black wires flush at each end)
The input wires (2 Black go to R/L1 & T/L3/N on this drive, these wires are all in line with the motor terminals, Don't put wires on any other Terminals or you will see some smoke
Page 20 of the PDF shows how for your shielding
Page 26 shows for your wiring
