586,108 active members*
3,174 visitors online*
    Mar 2005
    15
    Bridgeport EZ-TRAK DX-2
    I have bought an EZ-TRAK II and I am trying to install the linear comps. I have a Starrett Webber Standard Mounted on the table, and I program a move of 20 in. The indicator is zeroed out at the right side and I move the table to the right or minus direction. After the move I read the indicator at the 20 in. programed move. The indicator now reads plus .006 I install the parameter code and write in minus .006 in the x-axis box and press plus or save. I turn the machine off, reboot the machine, check to see if the minus .006 is in the x-axis box, then home the machine. I program the 20 in. move and the distance remains 20.006. I removed the BMDC Board, cleaned the contacts with an eraser, reinstalled the board. This did not make any change. I ordered a ner BMDC Board and went through the same process; however, no changes have been made in the 20.006 Why can I not get the correct reading at 20.000?? Zukes 3140
    Nov 2004
    3028
    There is backlash comp and there is pitch error comp. The backlash comp is to take out mechanical play in the specific axis. The value placed in pitch error comp is for comping 30 inches. Make sure your knee is locked!
    George
  1. Bridgeport EZ Trak Flashdisk question:
    By marx911 in forum Bridgeport / Hardinge Mills
    Last Post: 01-30-2010, 02:09 AM
  2. Bridgeport Trak CNC2
    By n174k in forum Bridgeport / Hardinge Mills
    Last Post: 12-27-2007, 08:56 PM
  3. Where to buy CNC parts EZ TRAK SXII Bridgeport milling
    By yuso in forum Bridgeport / Hardinge Mills
    Last Post: 12-18-2005, 08:03 PM
  4. How do you make Bridgeport execute program?
    By Bill Gillen in forum Bridgeport / Hardinge Mills
    Last Post: 06-14-2005, 02:26 PM
