I did a search for how to remove the knee from a series 1 mill. Did not find any thing on removing the knee. Can someone point me in the proper direction. Thanks
assuming you have already removed the table
support the knee with a crane
unbolt knee screw from base of machine
looking at the machine ,on the left , on top of the knee , remove the cover , remove gib screw and gib
lift up with the crane and rotate the knee out
if that don't work loosen the four bolts holding the base of your ram to the base of the machine and rotate it out of the way , and lift the knee off
thanks, I am in the process of cleaning up and changing the grease.
