586,047 active members*
3,765 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Precision Plasma LLC 2' x 3' DIY Plasma Table
Results 1 to 10 of 10
    Dec 2007
    93
    Precision Plasma LLC is pleased to announce the release of a new 26" x 36" DIY plasma table. Precision Plasma LLC is working on providing low cost, high quality CNC plasma tables for the hobbyist and small business owners. We only provide the mechanics of a system which allows the end user to choose the electronics and software that meet their needs. The table is compatible with nema 23 stepper motors. MOTORS AND ELECTRONICS NOT INCLUDED.
    Specifications:
    • 26" x 36" cutting area
    • Aluminum gantry with hardened v-rails
    • 5" travel Z axis with built in "float" for "touch and go" plasma cutting
    • 16 gage stainless steel water pan
    • 1/8" x 3" hrs slats
    • Resolution of .001" when using tenth step drives direct drive
    • 500 IPM rapid traverse X and Y, 50 IPM for Z axis
    • Acceleration of 50in/sec/sec
    • 1" clamp collar to attach the plasma torch (adapter may be needed for your exact torch)
    • Compact size for space savings
    • Lower frame supports plasma unit
    • Casters for mobility
    • Upper frame can be removed and used as a portable cnc plasma
    • Powder coated frame
    • "C" channel frame allows parts to be cut from full sheets of material.
    • "Patent Pending" design
    Precision Plasma LLC sells a full line of DIY machines and kits ranging from 4' x 4' to 5' x 10'. Besides complete tables, we also will provide gantry kits for people looking to save more money. Contact me with your requests and I will be happy to offer you a kit to match your exact needs.
    The kit shown above consists of the gantry and rail mechanics of a cnc plasma table. Everything else needs to be sourced by the consumer. It requires (4) nema 23 stepper motors with 1/4" shafts with 276 in-oz torque or greater. Complete packages can be sourced from candcnc.com or many other vendors on the web.
    In order to keep costs low, Precision Plasma LLC has chosen not to sell the electronics or motors with the machines. The support for the mechanics of the table is provided by Precision Plasma LLC. Support for the electronics must be sourced from the vendor which you purchase from. If you don't require support, you can piece together an electronics package with torch height control for under $800. Ebay is a great source for basic electronics and motor packages. If you require support, I suggest purchasing a complete package with unlimited technical support from candcnc.com for $1,250. (New lower price) Also, Mach 3 and Sheetcam software can be purchased from candcnc.com as a package for $299.
    Table Pricing:
    Base unit consisting of upper and lower frames, rails, Z axis $2,000
    3" 16 ga stainless pan with integrated slat holders $300
    1/8" x 3" x 41-3/8"lg HRS slats (set of 10) $100
    (You can source locally to save on cost and shipping weight)
    Wiring arm (not shown) $100
    See the Precision Plasma LLC website for other products.
    Best Regards,
    Ron Chacich
    [email protected]
    Dec 2007
    93
    Economy Build Costs
    Lowest Cost Build:
    Table:
    2X3 table without water pan, arm, or slats $2000
    A grate weldment can be made from (2) 20' lengths of 1/8" x 3" HRS $40
    Total Mechanical cost $2040
    Electronics:
    Geckodrive G540 $249 (Ebay) or Cnczone
    (4) 276 in-oz stepper motors (Automation Direct) 4 x $39 = $156
    Motor cables (Automation Direct) 4 x $13 = $52
    Power supply (Ebay) $39
    Relay (Ebay) $10
    Enclosure (Home Depot) $15
    Total for Electronics = $521
    Software:
    EMC2 (Enhanced Machine Control)
    Free Linux machine controller
    Total cost without Torch Height Control $2561
    With Torch Height Control:
    Subtract $10 for relay
    Add candcnc.com LCTHC $199
    Total cost with Torch Height Control $2750
    Dec 2007
    93
    Optimal Build Costs
    Cost for an optimum build of a Precision Plasma LLC 2x3 Table:
    Table:
    2X3 Table $2000
    3" deep 16 ga stainless water pan $300
    Wiring arm $100
    Source the slats locally to save on material and shipping costs: $40
    Total Mechanical Cost: $2440
    Electronics:
    Bladerunner AIO 300-4 with Dragon Cut THC from candcnc.com $1250
    Unlimited technical support included
    Total Electronics Cost: $1250
    Software:
    Mach 3 and Sheetcam TNG
    You can purchase as a package from candcnc.com for $299
    Total Software Cost:$299
    Total system cost with stainless water pan and Digital Torch Height Control: $3989
    Dec 2007
    93
    Compatible Electronics
    Candcnc.com can supply a Geckodrive G540 kit to go along with their low cost torch height control (LCTHC).
    http://www.candcnc.com/LCTHC.html
    Add an enclosure, motors, and a power supply and you would have set-up compatible with the Precision Plasma LLC products.
    Dec 2007
    93
    Low cost electronics package
    In order to further reduce the cost of the table, I have sourced another electronics package which would be compatible. It is from a company called deepgroove1.com.
    The controls package is based on the Geckodrive G540.
    This a 4 axis system with control box, motors, cables, and relay for $600
    Deepgroove1 Gecko control box
    The Precision Plasma LLC 2' x 3' upper gantry, this electronics package, and EMC2 software would make up a complete system. (less a computer and plasma cutter)
    The cost to get into CNC Plasma Cutting is now down to $1700 for the portable gantry, $600 for the electronics, and $0 for the software. For a total of $2300, you would have a system. This would not include torch height control, but you could add the LCTHC from candcnc.com for $199.
    The lower frame, wiring arm, stainless pan, and slats are extra as described in the earlier post.
    Jul 2005
    2415
    Quote Originally Posted by rchacich View Post
    A few points of clarification:
    1. The $199 price on the LCTHC is a special introductory price and only good until NOV 15th (a week from next Monday). After that, it moves to $249.00. The LCTHC-G540 combo pricing will stay the same.
    2. The LCTHC does not have EMC2 support (yet). MACH3 is required. SheetCAM is highly recommended.
    3. We offer Phone, Direct E-Mail and On-line forum support for any products purchased from CandCNC including the G540 and software packages. All our manuals are PDF (written) and available on line in our Manuals section of the website.
    4. Hooking up the LCTHC to the G540 requires access to the 12 pin connector on the bottom of the G540. We have a custom interface card (G540 Interface Card) that makes it a simple plug-in and single cable to the LCTHC. The G540 Interface Card will probably not work with the DeepGroove controller box. The G540 Interface card includes a 10A aux relay in addition to the Torch Relay on the LCTHC THC SENSOR card.
    5. There are quite a few features the LCTHC lacks compared to our DTHC. There is a comparison chart at http://www.candcnc.com/DTHCCompareChart.htm (I know, it's tedious) LCTHC does not have support for our new Digital Current Probe (DCP-01) or the new auto-learn (Smart-Kut).
    TOM caudle
    www.CandCNC.com
    Dec 2007
    93
    We have stock on 4 of these tables at this time. The lead time is less than 1 week to package and ship.
    Dec 2007
    93
    All of the tables have been sold at the introductory price.
    Jan 2009
    87
    You sir must have the absolute best tables in the world. If i was not on such a budget, I would of certainly knocked at your door before anyone else.
    Precision plus CandCNC, does not got any better!
    Anything is possible, just build it!
    Aug 2010
    yep pretty good prices for what it is also. if i didnt want to build my own stuff and go linear rail route i would have bought a precision setup
  1. Precision Plasma LLC History
    By rchacich in forum Waterjet General Topics
    Last Post: 03-02-2015, 05:44 PM
  2. Precision Plasma 4x4 CNC Table Build
    By unixadm in forum Waterjet General Topics
    Last Post: 12-13-2014, 10:31 AM
  3. Precision Plasma LLC 3 x 4 table final assembly
    Last Post: 09-06-2010, 04:23 PM
  4. Precision Plasma LLC 6" rotary chuck for CNC plasma cutting
    By rchacich in forum News Announcements
    Last Post: 05-26-2010, 06:57 PM
  5. Precision Plasma LLC 5' x 5' CNC Plasma Table
    Last Post: 11-10-2009, 05:08 PM
