586,222 active members*
3,511 visitors online*
    Nov 2007
    12
    Random circles in Alphacam
    I can't figure out where these circles are coming from. Short of weeding out any offending code manually does anyone have any ideas? picture and alphacam file attached in zip.
    Attached Files Attached Files
    Mar 2009
    144
    Mach3 has a setting for incremental or absolute arcs. I don't have it in front of me so I won't be much more help than that. It's one of the main configuration sections and is very likely your problem. The CAM software will need to match the Mach3 setting. Good luck.
    Ken
    Nov 2007
    12
    In case anyone has the same issue, I just needed to select a linearized post in alphacam.
    Feb 2011
    I am having the same problem. Oddly enough I too am making a plaque of sorts for a loved one who has died. I was doing some 3D engraving with no problem, the issue comes when I try to Pocket Engrave.
    I am not sure what the linearized post is you are talking about.
    any ideas? or can you give me some more info on the linearized post?
  1. random stalling
    By ihavenofish in forum Gecko Drives
    Last Post: 07-10-2010, 11:07 PM
  2. Random Z movement during job
    By Lindzr in forum DIY CNC Router Table Machines
    Last Post: 05-12-2009, 11:54 PM
  3. circles arent circles
    By xlr8r in forum DynaTorch
    Last Post: 01-18-2009, 06:26 PM
  4. random estop
    By erase42 in forum DeskCNC Controller Board
    Last Post: 02-03-2007, 12:28 AM
  5. random thought
    By 2muchstuff in forum DIY CNC Router Table Machines
    Last Post: 02-16-2005, 04:46 AM
