586,114 active members*
2,987 visitors online*
Thread: Parameters
    Jun 2010
    60
    Parameters
    I have seen Chuck models that are controled by parameters, how can i make this myself?
    I have a chuck in my 4th axis and would also like to make a flexible vice this way.
    I dont really want to do it with PCI this solution seems much better and edgecam has support for it it seems.
    Jun 2010
    60
    Solution was to restore parametric model in the post, then add it again and not delete the chuck then i got it after lots of pain.
    Got reply from support to finally.
    with the same solution as i just had figured out.
    But the sad part is that it cant be done with normal solids in edgecam = i cant make a vice this way.
    and worse the chuck is just a ghost image it cant be used to check for collisions against =( so 2 weeks of testing for nothing.
    I will build my environments in solidworks instead and then import it all at once together with the part to mill.
  1. CAM T3- K PARAMETERS
    By CHANDRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-24-2010, 08:01 AM
  2. Need parameters for SMG
    By RRL in forum Fanuc
    Last Post: 03-25-2009, 07:02 PM
  3. Cannot see my 900 parameters in my 0M-C
    By elvicash in forum Fanuc
    Last Post: 02-25-2009, 02:44 AM
  4. plc parameters
    By savancnc in forum CNC Machine Related Electronics
    Last Post: 12-11-2007, 09:48 AM
  5. G83/G87 parameters
    By DocHod in forum Fanuc
    Last Post: 11-04-2007, 08:54 PM
