Originally Posted by
Harryp
I've seen various packages on ebay but am not sure if I will be able to get the software for the drive anymore. Any input would help.
Why do you need an intelligent drive that requires software?
Surely you can use a simple PWM drive with analogue (10k pot) input.
There are many Advanced Motion on ebay that should do the trick.
A servo motor with an encoder back to the drive will maintain the rpm.
These drives you can get with self contained power supply up to 100amp drive.
The BLDC types will drive both BLDC and brushed DC motors.
The 25A20AC should be sufficient for what you want to do?
Al.
Albert E.
