586,036 active members*
4,343 visitors online*
Results 1 to 17 of 17
    Oct 2010
    Fanuc OM electrical schematic
    Hi, I am an electrical engineering student and am doing a project that consists in removing a CNC controller and replace it to a PC with free software and create an interface between the PC and machine, keeping theb same part of the power control of motors. I need help to choose the software and finding the wiring diagram of the controller FANUC OM. The CNC machine is a CORTINI 3.F.400 1989 with automatic tool change. I have some references of the controller boards if necessary. Thanks
    24221
    I can probably help with a connection manual for the 0, there were a few versions which used different servo drives.
    The interface on most of the Fanuc systems is proprietary so you may have a problem interfacing.
    Also with a tool changer you may want to look at an outboard PLC to carry out this function.
    PM me an email address if you want the manual.
    Al.
    Albert E.
    Sep 2010
    125
    i can also send you a connecting manual but you must first choose witch kind of fanuc 0 you want... just one thing, you need a PG programmer with a rom writer on all the 0 system exept with 0i to create your pmc... hard to do il you don't have any knowledge on fanuc...
    Oct 2010
    Thanks Al_The_Man for the link and thanks tmbruno28.
    I know it´s hard to do but it´s my project of school.
    I have photos and references of servo motors. I don´t know if they are AC or DC motors but i think they are AC because they are 3 phase. look the pictures.
    The tool change will leave to the end.
    First I will focus on command at least one axis of the machine through the PC.
    I will investigate what type of fanuc o I have.
    Even now, where can I find (in controller or machine) what type of fanuc 0 that I have?
    24221
    Yes. AC servo's, normally they have a Red cap, the DC have a yellow cap.
    Al.
    Albert E.
    Sep 2010
    125
    ok, you have 0B system, mother board must ref must ended by 0285 or 210, but the most important is that you have a pmc L type.
    Did you have tool to edit a new ladder ??
    Oct 2010
    Quote Originally Posted by tmbruno28 View Post
    No, I don´t have tool to edit a new ladder.
    The reference of motherboard is:
    Fanuc 0M-Model B
    A02B-0091-B501 No.9064306
    Date 1989-06
    thanks
    24221
    I thought you intend fitting new controller, if so you cannot use the Fanuc ladder (PMC/PLC).
    Automation direct is a cheaper one with free software.
    Al.
    Albert E.
    Sep 2010
    125
    how can you use digital servo (6058 series) with an plc other than fanuc ???
    Oct 2010
    Al.
    No, I want to eliminate the old controller (gabinet) because it doesn´t funtion. But I have to take the part of the engine power control.
    Now I have an PC with EMC2 software to control the CNC machine but I need to make the interface between the PC and the old drivers of servo motors.
    Oct 2010
    Al.
    yes, my servo's have a Red Cap.
    thanks
    Oct 2010
    Quote Originally Posted by Nuno_CNC View Post
    Fanuc 0M-Model B
    Date 1989-06
    thanks
    Hi, the reference of motherboard is A16B-1010-0285 /15B instead of previous.
    Oct 2007
    179
    Shame to remove the Fanuc which is a better controller than the EMC!
    John
    Feb 2011
    640
    before taking that Zero out, better be sure your PLC can handle Fanucs 4 channel grey code servo commutation and straight PWM output... I believe Delta-Tau CNC was the only ones that ever succeeded...
    I dont think the 'B' used them, but- if youve got serial encoders forget it.
    Apr 2010
    40
    I found only FANUC 0 series schematic & electronic circuit on eBay.
    But not sure it is applicate for 0 series model B or not.
    Try to search "FANUC Schematic" on eBay, hope the results can help.
    Continue happy with works hard.
    Apr 2010
    40
    Re: Fanuc OM electrical schematic
    Quote Originally Posted by develop1 View Post
    Update : https://www.ebay.com/str/pumazo
    Apr 2010
    40
    Free download FANUC 10-11-12 M/T Maintenance manual
    http://store.payloadz.com/go?id=2648541
  1. Milltronics Partner 04 Electrical schematic
    By go0869 in forum Milltronics
    Last Post: 03-01-2013, 05:39 PM
  2. Electrical Schematic, please
    By bassdoctor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-05-2011, 12:35 AM
  3. Arrow 500 Electrical Schematic needed
    By Hypermold in forum Cincinnati CNC
    Last Post: 04-14-2011, 02:03 PM
  4. Electrical schematic
    By JerryF in forum Uncategorised MetalWorking Machines
    Last Post: 11-06-2008, 07:34 PM
  5. Electrical Schematic review
    By JerryFlyGuy in forum CNC Machine Related Electronics
    Last Post: 06-20-2007, 06:37 PM
