I have a hardinge HNC converted to run on EMC2. I kept the stock servos, amps, power supply, and resolvers. I am using a pico systems resolver to encoder converter for both axi.
The lathe was working great for a while, and eventually i started getting joint following errors for the x axis. I noticed it was only in one direction (x-), and when it did it, the movement was pretty rough. If i went x+ for a second and went back to x-, it was usually ok. I slowed down the velocity so i could still run parts and it helped for a while, but now it's to the point where it's almost unrunable. Even at like 10ipm, it'll still fault. It does not appear to be anything mechanical.. if i turn the leadscrew by hand, it works great. Also, i tried changing the belt and it did not help. I do not think it is the resolver or the pico board (i tried swapping the pico board with the z axis and it didnt follow the board). The machine is still holding a good tollerance, and it doesnt run away. I'm thinking either amp or servo. Since it's only in one direction, i'm wondering if maybe it's a brush? (brushed DC). Has anyone had this problem and figured out what it was? I know i can swap amps and see if it follows the amp, but i figured i'd ask first. I'm going to attempt to go pull the brushes to check them out.
Thanks in advance,
Dan
