586,068 active members*
3,706 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Need help finding specs for DIN 332-D M12 center
    Jun 2004
    7
    I have wasted so much time search the internet for the geomerty specs of a center in the end of a shaft designated as "DIN 332-D M12". My customer has provided the drawin with this spec on it, and he has no information on what it is, and I cannot find it anywhere.
    Can anyone please point me to where I can find complete specs (angle, c'bore dia, depth, thread depth, etc.)
    Mar 2006
    2712
    My AutoCad has DIN 332-A, -B, -C & -R but no -D. I thought I could print it out and measure it, but no luck.
    Dick Z
    DZASTR
    Mar 2008
    240
    Mattslay - DIN 332 -D M12 is listed Under DIN 332 T 2. To get all the dim.s you need to get DIN 332 Part 2. It is a center with straight (straight 60 deg) flutes and 10.2mm dia at the first point and 13 mm on the second step. Listed as 60 deg. center with thread for shaft ends on electric motors. No protective c/sink.
    Hope this helps you. Juergen.
    I found this:www.b-aer.de/pdf/seite045.pdf
    It should give you all you need. View in the upper left gives you the dim's for the center drill DIN332, Type D, M12. The smaller dia guides inside the thread, the next dia clears out a part of the thread.
    Mar 2008
    240
    Added note ; The smaller dia. IS the tap drill. In your case for M12 it is 10.2 by 28mm long (L 2).
  1. need help finding specs on motor
    By CNC Darren in forum Stepper Motors / Drives
    Last Post: 06-06-2012, 12:59 AM
  2. finding center of a hole
    By BeerFizz in forum Mach Mill
    Last Post: 06-15-2007, 01:17 AM
  3. Help finding specs on Vexta Stepper
    By scratch_6057 in forum Stepper Motors / Drives
    Last Post: 01-11-2007, 07:56 AM
  4. Finding the center
    By Tazzer in forum MetalWork Discussion
    Last Post: 08-05-2006, 06:18 PM
  5. Helpme finding this specs pls.....
    By Calico in forum Stepper Motors / Drives
    Last Post: 07-11-2005, 04:40 AM
