I have posted a few previous outlines on the Fanuc encoder, the last three numbers tell what type encoder, absolute or incremental/differential.
The C1-C8 is the proprietary commutation code for the AC servo motor.
There is a member here that has built a circuit mod for the commutation to standard BLDC.
You should find the PDF posted previously on the commutation pattern.
Al.
Albert E.
