586,116 active members*
3,324 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Q: Best way to cut small oring groove?
Results 1 to 9 of 9
    Sep 2004
    412
    What is best way to cut a 1mm o-ring groove to a .75mm depth on a mini lathe.
    I'm considering using a small drill bit. Is there a better way to do this?
    The machining adventure continues. = )
    May 2005
    1810
    OD or face?
    What's the material?
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Mar 2005
    988
    HUH????
    Apr 2003
    470
    Quote Originally Posted by psychomill
    HUH????
    Exactly...
    Grinding an appropriate form tool is the correct way to do it...
    Nathan
    Apr 2003
    1873
    Grind the desired width into a cutter, I have found that it does not have to be round just grind the end square and chamfer the outside. Here is a picture of one ground for a inside. It is looking down from the top, of course a relief has to be ground on the underside.
    May 2005
    1810
    Ken -
    Based on the uniformity of the burn marks, that tool looks EDM'd to me....you cheater!
    Deviant -
    I have frequently used a part off tool for OD grooves since it eliminates a lot of grinding.
    Face grooving tools for small diameters require either a lot of attention or a very frail cutting edge. Let us know if you need some pointers.
    :cheers:
    Scott
    Sep 2004
    412
    It's on the outside of the of the piston...
    I was considering using a broken drill bit, ground flat. Similar to how people use them to make a boring bar. I was just going to make a 1/4" clamping fixture to hold the bit in my tool post.
    Grinding a 1/4" tool bit down to less than 1mm is going to be interesting...
    Maybe I'm over thinking it.
    Apr 2003
    1873
    No EDM here, just a cheap grinder and about 20 minutes
    May 2005
    1810
    .....ground by hand - what-everrr (in my best SoCal female voice). It's your story - tell it how you want.
    (J/K!!!) - I am in a goofy mood - painkillers are a guud thing!
    Good work, Ken. Your patience is obvious. Looks really good.
    Scott
  1. Kcam Cut depth
    By 47MLB in forum Uncategorised CAM Discussion
    Last Post: 01-18-2012, 08:04 PM
  2. cutting oring groove
    By fastolds in forum BobCad-Cam
    Last Post: 06-17-2005, 08:26 AM
  3. cut single, cut auto and cut all???
    Last Post: 10-06-2004, 02:15 PM
  4. PICS - BOAT HULL CUT WITH CNC
    By ninewgt in forum DIY CNC Router Table Machines
    Last Post: 08-03-2004, 12:21 AM
