586,042 active members*
3,748 visitors online*
Results 1 to 7 of 7
    Feb 2009
    yaskawa 626 varispeed
    the control keeps blowing out the high voltage capacitors. runs for a couple of days then the caps explode. anyone seen this problem before the caps are 2200ufd 450v
    Sep 2010
    I had this yeasr 3 tims problems with Yaskawa units. (2 problems on a VM25 miltronics machin) and one on Mazak laser machine st48 turbo, but id din't blow simply they was damage
    Mar 2008
    169
    Please more data. Did you check the input voltage?
    Carlos
    15362
    george9
    I think you have a input voltage problem, or something else in the drive that has a problem
    We have new Yaskawa 626 drives if you need them
    Mactec54
    Feb 2009
    the caps blow out randomly , not always the same one. we replaced all of them and since then 2 have exploded on seperate times. going to check input voltage when we return it to cust
    Feb 2005
    Problems with 626 Drive
    Hi I too am having problems with my 626 control. I am getting a F400 error and sometimes a F800 error. Any idea what might be causing this and what part would need replacing or do I have to buy a new drive. Any help appreciated
    15362
    StoneCutting
    The F400 is Inverter over-voltage,Check the input voltage, this could be your problem, the F800 excess speed deviation this could be encoder wiring or the encoder
    This PDF may help you a little to find your problems,
    Seems to be a problem making an attachment
    Mactec54
  1. Varispeed VFD conversion
    By DSE in forum Bridgeport / Hardinge Mills
    Last Post: 12-09-2014, 12:50 PM
  2. BM54V Varispeed Mill
    By Kiwi 007 in forum Benchtop Machines
    Last Post: 05-05-2009, 12:46 PM
  3. Yaskawa Varispeed 626 MT
    By bradodarb in forum Phase Converters
    Last Post: 04-27-2009, 02:38 PM
  4. Yaskawa Varispeed Spindle Drive component ID
    By rbleth51 in forum CNC Machine Related Electronics
    Last Post: 07-13-2007, 10:18 PM
  5. r2e4 varispeed with retrofit.
    By najnielkp in forum Bridgeport / Hardinge Mills
    Last Post: 11-01-2006, 04:06 PM
