As the title implies I have a Hitachi SJ200-015NFU2. I also have two 33 ohm 150 watt resistors that I want to use for braking.
Page 2-8 of the manual suggests that the braking resistor goes between the + terminal and the RB terminal. Page 2-20 shows these terminal with the + terminal having a jumper to the +1 termina.
I am assuming that I can put the two resistors in series for a total of 66 ohms and then attach them to the + and RB terminals and be good-to-go. I thought I saw that the Hitachi braking resistors were in the 50 ohm range so I also assumed that 66 ohms would be close enough and would error on the conservative side.
Does anyone care to comment on this plan? Good? Bad? Lost my mind?
Arvid
