586,384 active members*
3,633 visitors online*
Results 1 to 9 of 9
    Sep 2006
    94
    Question Mori Seiki Fanuc O-T Alarm 100 p/s
    Hello.
    We just got a very nice looking Mori Seiki SL-25B5 with a Fanuc O-T control.
    I have an Alarm 100 p/s.
    I can zero out the X and Z and jog them around.
    I have absolutely no documentation on this machine (serial number 3432).
    How do I figure out what memory has been lost? (out of service for several years)
    I might have a Fanuc O-T manual.
    Any help would be appreciated.
    Heath
    24223
    Alarm 100 is usually when the PWE 'Parameter Write Enable' bit is set, this can be confirmed on the 'Setting' screen.
    This will usually put the machine into E-Stop!.
    Do you have the parameters on the machine?
    900 Options, user par. and diagnostic counter/timers in either hard or soft copy?
    Al.
    Albert E.
    Feb 2009
    6028
    It won't estop a Mori. You can even hit cancel and reset at the same time and the alarm will clear, allowing full operation of the machine.
    Sep 2006
    94
    Thanks for the replies fellas.
    Al, I have no documentation on this lathe.
    underthetire, I will give that a shot tomorrow morning.
    Heath
    Feb 2009
    6028
    You still will need to eventually turn off PWE in the settings page.
    24223
    If you P.M. me an email add I can help with the manual.
    Al.
    Albert E.
    Sep 2006
    94
    Will do Al.
    I cleared the alarm. I can get the spindle and axis' to jog now.
    Thanks!
    I have a turret alarm now but I will start a new thread on that one.
    24223
    If you have the right 0T version you should be able to trouble shoot that with the on screen ladder display.
    It is turned on by a user parameter if it is displayable.
    P0060 bit #2.
    Al.
    Albert E.
    Feb 2009
    6028
    Mori usually has a displayable ladder. Sometimes it asks for a password, type in "L" then hit input. Post the alarm and i can help.
  1. SERVO ALARM 401 REPEATING IN MORI SEIKI
    By CHANDRU in forum Mori Seiki lathes
    Last Post: 06-25-2020, 10:38 PM
  2. Mori-Seiki SL-0 / Yasnac LX1 Alarm Code 332 Help!?!
    By larrynsr in forum DNC Problems and Solutions
    Last Post: 01-11-2013, 09:46 PM
  3. Mori Seiki Fanuc 6M ALARM ERRORS
    By HouTX in forum Fanuc
    Last Post: 12-02-2010, 12:55 PM
  4. Memory alarm on Mori seiki lathe
    By hectorbach in forum Mori Seiki lathes
    Last Post: 01-06-2010, 01:04 AM
  5. Mori Seiki SL-20 Fanuc 10T
    By premier_industr in forum Fanuc
    Last Post: 12-15-2009, 02:55 PM
