586,069 active members*
3,662 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > K2CNC > Question about K2 CNC machine material used...
    Jan 2010
    I saw a K2 CNC unit once that had a white plastic board- I dont know if it was a part of the table, or custom, or something that went on top of the table that a jig was set up on.
    Anyway, it was like a plastic-y type material, white, and something like a cutting board type material.
    I'm not sure if its a K2 option, but I've looked online and cant find any reference to it. Does anyone know what this material is called? I want to use it for a base to a small polisher set up, but dont know what key words to type in Ebay. I've seen this in white and I think black ...
    Any help would be appreciated!
    Thanks!
    Aug 2009
    14
    My guess would be high density polyethalene (HDPE). It is a food safe material used to make cutting boards. Pretty affordable too. It is tough and stable and I know some have used it to make tables for their CNC machines. It might be what you are talking about.
    The only table top I've seen from K2 is extruded aluminum.
    Plastic that you've seen that comes in black or white could be Delrin, but it is pretty expensive to be using for a table top. Many use Delrin to make anti-backlash leadnuts. It is a very tough and slippery plastic.
    Another good plastic for the base of something might be Corian. It is also sometimes used to make cutting boards. Available for free if you know someone who installs counter tops. It machines well, looks like stone sometimes, and is much harder than HDPE or Delrin.
  1. Material ID/Capacity Question
    By TravisR100 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-02-2010, 09:33 AM
  2. Best Material for Machine Bed Riser
    By mfa330 in forum Uncategorised MetalWorking Machines
    Last Post: 09-29-2009, 08:07 PM
  3. Belt material question?
    By satguy in forum DIY CNC Router Table Machines
    Last Post: 06-20-2009, 02:45 PM
  4. Material strenght question...
    By croosh in forum DIY CNC Router Table Machines
    Last Post: 02-20-2008, 02:41 AM
  5. Material for lathe bed question
    By jdholbrook in forum Uncategorised MetalWorking Machines
    Last Post: 05-01-2006, 05:05 PM
