587,475 active members*
3,294 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > can i use this for variable speed spindle control?
Results 1 to 8 of 8
    Oct 2004
    298
    i got a woodworker's catalog in the mail today, as i usually do, and when i was thumbing through it, i found a little box that allows you to turn your router into a variable speed one. it claims it doesnt lose power at lower speeds, so presumably its a PWM converter or whatever.
    it appears to work at 120V, 15A and with a motor less than 3.5HP. so, it should work power-wise with a smaller bench-type single-phase milling machine. could you just plug the machine in and get a variable spindle speed? this would stop changing belts.
    also, if you attached one of those optical tachometers to it, you could get a decent speed control on the cheap.
    746
    Could you be a little more specific regarding the speed control. Pictures or a link to one would be helpful. If it is one of the small speed controls that I'm thinking of then it is a triac style. PWM speed controls are genarally larger in size and cost more.
    Router motors use a brushed type of motor and respond well to triac speed controls.
    Single phase milling machines use an induction type of motor and do not respond well to triac speed controls.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Apr 2003
    361
    Probably one of these...
    http://www.mlcswoodworking.com/shops.../speedcon.html
    Stupid questions make me smarter...
    See how smart I've become at www.9w2bsr.com ;-P
    746
    Those are the triac type, great for brushed motors, bad for induction motors.
    Apr 2003
    361
    Quote Originally Posted by 2muchstuff
    Is this true? That being the case, can I use normal light dimmer (triac-based) for the task (after adding the snubber circuit or replacing the triac with built-in snubber to take care of the motor induction problem )?
    24220
    The controllers shown are OK on Universal motors, the type used in most power tools etc, they are for AC or DC brushed series connected motors, but do not use them on ordinary 1ph induction motors.
    Al.
    Albert E.
    Oct 2004
    298
    so, what could be used on an induction type motor, if anything...
    Jun 2005
    65
    an ac motor designed to run on 60hz is not amenable to speed control of any kind - you can merely adjust power output
    dc motors are easy but if you want any sort of tight regulation under load you need a tach/controller integrated.
    this is actually pretty easy for relatively small motors up to 10 or 20 A if you don't mind soldering up some logic and pwerfets and a big old heat sink
  1. CNC Controlled Spindle motor speed control
    By gregmary in forum CNC Machine Related Electronics
    Last Post: 02-28-2009, 02:01 AM
  2. Taig Mill - need speed control for spindle
    By t2436jf in forum Taig Mills / Lathes
    Last Post: 01-24-2006, 10:37 PM
  3. BP spindle speed control
    By zcases in forum Mach Software (ArtSoft software)
    Last Post: 06-15-2005, 03:06 PM
  4. Spindle Speed & Feed Rates - Question
    By Moondog in forum DIY CNC Router Table Machines
    Last Post: 07-24-2004, 12:24 AM
  5. CNC spindle and fluid control
    By replicapro in forum CNC Machine Related Electronics
    Last Post: 06-22-2004, 07:37 PM
