Seeking a maintenance-free motion control solution that ensures radial position and integrity? Look to PBC Linear’s square bearing products. Designed with our proven Frelon liner, Simplicity® Square Bearings thrive in adverse working conditions over extended periods of time.
• Wide working temperature range (-400°F—400°F/-240°C—204°C)
• Self-lubricating/Maintenance-free
• Handles high shock loads
• Low wear rates
• Loads up to 450 lbs. (per plug)
Running along a square 304 stainless steel shafting, Simplicity® Square Bearings can maintain radial integrity for assured application performance. Corrosion and wear are no problem. Simplicity technology is designed to thrive in tough environments: contamination, heavy particulates and caustic chemicals. Simplicity Square Bearings also perform well in clean-reliant applications. Self-lubricating and oil-free, our square bearings provide smooth and reliable linear motion without corrupting or contaminating the application.
For more information on Simplicity® Square Bearings or any of PBC Linear’s other motion control products, please call 1.800.729.9085, email to [email protected] or visit us at our newly designed website at Linear Motion Bearings, Linear Actuators, Linear Guides, Profile Rails, Cam Rollers.
